Converting A Tinplate Loco To Live Steam
18 replies to this topic
#16 johnR
johnR
  • 2,295 posts
Posted 06 February 2023 - 07:07 PM
Great project.
There are going to be lots of challenges to overcome. A metho burner will likely wreck the paint regardless of the type. Looping through the flame causes thermal runaway and will chew through the fuel too fast to heat the boiler properly.
The best option would be a flue boiler (flame tube) with a butane burner, cleaner, hotter and keeps the flame away from the paintwork.
And there are plenty of plans, ideas etc on the web for converting and building steam trains, trams etc to give inspiration.
I've seen some videos covering a gauge 1 'Cracker' loco which is gas fired - perhaps I'll try it - hopefully the gas will burn OK in a 15mm fire tube as that's about as big as I can go..
#17 DeadSquare
DeadSquare
  • 3,086 posts
Posted 07 February 2023 - 12:15 AM
Great project.
I am sorry if I'm dousing your aspiration, but as someone who has been playing with O gauge live steam for over 65 years, there are limitations.  The scale of Gauge 1 makes many things much more feasible, but flame, steam generation and piston efficiency don't scale down.
The big downside to your one, oscillating, single acting.cylinder, is that although its port admits steam when the crank is coming up to the optimum position, the piston isn't, As you only get 1/3rd of a power stroke, and the driving wheels (plus your crank webs) rotate too slowly to accumulate much flywheel effect, you need two cylinders, which consume twice as much steam.
It can be done, I have a Bowman's O gauge live steam tank engine, but the external cylinders and connecting rods leave a lot to the imagination, compared to my Bassett-Lowke locomotives with their double acting, valve operated cylinders.
BUT
Please don't let my 2d worth spoil your fun of fitting all the bits into your chosen space.
#18 DeadSquare
DeadSquare
  • 3,086 posts
Posted 10 February 2023 - 12:17 PM
To encourage you, ff you type "Bowman live steam locomotive" into Ebay, and scroll down to an odd looking £325 loco,  you can see how a single, single acting cylinder drives a flywheel on a vertical shaft that is geared to the axle.
With the £300 tank engine, there is an underside photo showing the position of it's 5 burners under the boiler.
Edited by DeadSquare, 10 February 2023 - 12:31 PM.
#19 johnR
johnR
  • 2,295 posts
Posted 15 February 2023 - 07:42 PM
I've seen one of those horizontal flywheel set-ups - but as you say it does lead to an odd look and I want to keep mine looking as stock as possible - even though that may make life more difficult for me. I think your suggestion of gas firing may be worth looking at if I can get a burner working in a length of standard water pipe @ 15mm coupled with a double acting cylinder.
