Wiring Question
electrical engine
3 replies to this topic
#1 Alan11985
Alan11985
    Just On Tickover
  • 8 posts
Posted 28 January 2023 - 10:17 PM
I am rebuilding a mini that I didn’t take apart so am unsure on certain wires. I have the new loom from mini spares (ham3684). I have a non ballast coil.
Am I right in thinking that this loom has the wires in it for both ballast and non ballast coils?
Also can anyone confirm where these wires go that are at the front around the grill?
2 white/black wires that are together?
1 single white and black?
1 white wire
1 pink wire ( for ballast coil?)
purple wire on it’s own (horn?)
what does the red and black wire on the distributor connect to?
basically what colour are the wires and where do they connect on the coil and distributor?
thanks in advance
Edited by Alan11985, 28 January 2023 - 10:33 PM.
#2 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 28 January 2023 - 10:22 PM
You should grab yourself a Haynes manual, all the wiring diagrams are in the back of the book.
If you're rebuilding a car you didn't take a part, the Haynes plus Mini Spares'/Somefords' exploded diagrams are going to be invaluable on your journey.
#3 nicklouse
  • 18,474 posts
Posted 28 January 2023 - 11:18 PM
While you wait for your workshop manual to arrive you can see the wiring diagrams here
https://www.theminif...agrams-redrawn/
#4 viz139
viz139
  • 656 posts
  • Local Club: Irish Mini Owners Club
Posted 29 January 2023 - 09:34 PM
2 white/black wires that are together?  To Coil -
1 single white and black?                       To distributor with points
1 white wire                                           Check if there is a yellow strip on the white .To Coil +
1 pink wire ( for ballast coil?)                 To Ballast coil +
purple wire on it’s own (horn?)                Horn
The Red and Black from the dizzy go to + and - on coil ,leave single white/black wire disconnected.
Also tagged with one or more of these keywords: electrical, engine
