Wiring Help. Inline Fuses
electrical
13 replies to this topic
#1 BenSwan
BenSwan
  • 43 posts
Posted 15 January 2023 - 08:45 PM
Hi all,
Does anyone know why a previous owner has added these inline fuses? I've tried looking at the wiring diagram but can not work it out.
I think the colours are 'blue' to 'blue/orange' and 'brown' to 'brown/orange'.
Is this something common and needed?
#2 nicklouse
  • 18,474 posts
Posted 15 January 2023 - 09:32 PM
What year car?
#3 nicklouse
  • 18,474 posts
Posted 15 January 2023 - 09:36 PM
And blue to Blue orange each side of a fuse was standard for the fog light.
and there are a few of those fuses in the cars.
Edited by nicklouse, 15 January 2023 - 09:39 PM.
#4 BenSwan
BenSwan
  • 43 posts
Posted 15 January 2023 - 09:47 PM
It's and A reg, 84 Mayfair.
The blue has a new inline fuse looking at the blue crimp connectors. Would it be that it used to have one like the brown and has been replaced?
Maybe it's just that which is making me think 2 have been added in.
#5 MikeRotherham
MikeRotherham
  • 975 posts
Posted 15 January 2023 - 11:04 PM
On later cars there are 6 inline fuses in that location.
I'd check on a wiring diagram for your model and year and see what should be there.
Could the fuse holder have been renewed hence the blue connectors and different coloured wires.
I'd double check what the wiring colours should be.
#6 Ethel
  • 25,865 posts
Posted 16 January 2023 - 02:20 AM
It could just be they've replaced an original fuse holder that rotted away.
#7 Steam
Steam
  • 705 posts
  • Local Club: Victorian Mini Club
Posted 16 January 2023 - 02:23 AM
The blue etc is the rear fog lamp, switch etc and is shown with an inline fuse as an additional accesory.
The other I would suggest is brown and orange purple which is also shown with an inline fuse and is for interior lamps and hazards.
If you check these circuits work then undo the fuse holder and see if they stop working it will prove the circuit.
#8 BenSwan
BenSwan
  • 43 posts
Posted 16 January 2023 - 07:37 AM
Thank the help all.
I'm starting to question if I'm using the correct haynes manual/wiring diagram. The one I have is this:
Which I'm using this diagram:
What keeps throwing me is the fuse box on the car has 4 terminals each side (8). But the diagram has a total of 4 (Number 19).
Am I reading it wrong? or do I need a newer manual?
#9 Steam
Steam
  • 705 posts
Posted 16 January 2023 - 07:53 AM
That diagram is for dynamo and toggle switches as it says at the bottom. The one you would need will be alternator and rocker switches and at least 1980 ish.
That being said the haynes wiring diagrams are not the best. Try to find a Leyland workshop manual.
#10 andyapanel
andyapanel
  • 618 posts
Posted 16 January 2023 - 07:59 AM
The wiring diagrams and codes for parts are printed back to back on my Haynes , which is not very helpful.
#11 nicklouse
  • 18,474 posts
Posted 16 January 2023 - 09:32 AM
Thank the help all.
You are looking at the wrong page. That one is for up to about 1971.
#12 BenSwan
BenSwan
  • 43 posts
Posted 16 January 2023 - 10:05 AM
Ok I think I've got the right page now and found the blue to blue/orange fuse (highlighted in red).
This is correct, yea?
I was having problems understanding that because when I was looking for the fuse box (Number 19) it only had 1 connection (2 points). I didn't realised theres 4 Number 19's on the diagram. ha!
#13 Ethel
  • 25,865 posts
Posted 16 January 2023 - 12:44 PM
The wire colours follow a standard scheme (mostly).
Blue is headlights, blue/white high beam, blue/red dipped. The fog light should be dependent on the headlights, because you should use both in fog & so you'll at least turn it off with the headlights if you forget to do so directly.
#14 Steam
Steam
  • 705 posts
Posted 16 January 2023 - 11:52 PM
Yes that is one, the other is the 67 inline fuse near the top just above the starter No 5.
