Minispares Iwis Evo Timing Chain 2H4905Evo No Longer Separable
engine
15 replies to this topic
#1 MiNiKiN
MiNiKiN
  • 191 posts
Posted 15 December 2022 - 01:15 PM
Hi!
FYI! As a warning to anyone who, like me, is considering fitting the above timing chain to avoid having to remove the sprockets for changing the chain, will be disappointed, just like I am.
Minispares now only supplies a one-piece as a replacement for the split one.
At first I thought that maybe the wrong product label had been stuck on it - but no - Minispares confirmed that this is now the case. Manufacturer is still IWIS; the IWIS part number is: 50036156.
I'm going to secretly blubber a little :cry: :cry:
Anyone know of this and the reason behind?
cheers
 Minispares EVO timing chain 2H4905EVO
Attached File  2H4905EVO_OLD.jpg   83.84K   0 downloads
#2 Ethel
  • 25,827 posts
Posted 15 December 2022 - 02:06 PM
If the chain is worn enough to require changing then, odds on, the sprockets are too.
#3 gav
gav
  • 693 posts
Posted 15 December 2022 - 03:58 PM
We changed them due to customer demand, none of the race engine builders wanted chains with a removable link. We will update the picture shortly. Apologies for the mix up.
#4 MiNiKiN
MiNiKiN
  • 191 posts
Posted 15 December 2022 - 04:13 PM
The old chain had only seen 4kmiles. I say, nothing wrong with the sprockets.
#5 Lplus
Lplus
  • 824 posts
Posted 15 December 2022 - 04:40 PM
I'd say nothing wrong with the chain either at that low a mileage.
#6 Spider
  • 14,665 posts
Posted 15 December 2022 - 04:47 PM
In my books, new chain also means new sprockets, though in your case with only 4000 on them, you'd likely get away with it, but fitting a new chain to otherwise worn sprockets, only wears what's left of the sprockets faster and the chain will also have a premature ending.
#7 MiNiKiN
MiNiKiN
  • 191 posts
Posted 16 December 2022 - 08:33 AM
The chain doesn't seem worn as such, but terribly streched.
Attached File  #4.jpg   60.32K   5 downloads
#8 Lplus
Lplus
  • 824 posts
Posted 16 December 2022 - 10:11 AM
Not sure what others think but I'd say that's about right for a run in chain.  There's a small amount of play necessary to fit the parts new and the running in period knocks off all the sharp edges and smooths out the mating faces of both chain and gears leading to a bit more clearance.  I just fitted a new single row chain and gears to an A+ motor and that much sag was already evident when I'd fitted the tensioner.  Presumably it wasn't rattling noticably?  I don't know what that much sag represents in cam timing inaccuracy.  Clearly you timed it in correctly, so how far out is it now?
Edit, I take it you lined up the gears with shims at build time.
Edited by Lplus, 16 December 2022 - 10:14 AM.
#9 sonscar
sonscar
  • 2,934 posts
Posted 16 December 2022 - 12:50 PM
Looks slack to me but then I am no expert.Primative variable valve timing?Steve..
#10 gazza82
gazza82
  • 2,993 posts
  • Local Club: TMF+
Posted 16 December 2022 - 12:53 PM
One I received was the incorrect part and too long. MS swapped it with no quibbles. The original sent was with the link, the new one was one-piece - the type I expected to get.
#11 imack
imack
  • 2,020 posts
Posted 16 December 2022 - 01:14 PM
That chain looks seriously slack!!
Any better pictures of the cam and crank sprocket teeth?
Chains don't physically stretch, rollers, pins and sprocket teeth wear creating increased distance between rollers that make a chain appear stretched.
Gold coloured sprockets are from Kent cams and are about 30 years old and chain is 7000 miles old - no excess slack. Silver MED sprocket and chain is new.
Edited by imack, 16 December 2022 - 01:28 PM.
#12 gazza82
gazza82
  • 2,993 posts
  • Local Club: TMF+
Posted 16 December 2022 - 02:15 PM
Looks VERY slack ...
#13 Ethel
  • 25,827 posts
Posted 16 December 2022 - 03:21 PM
That's a strange one. Obviously it wouldn't sit well on the sprockets if it was stretched that much, but it's hard to imagine there being enough for a couple of extra links.
#14 MiNiKiN
MiNiKiN
  • 191 posts
Posted 16 December 2022 - 04:25 PM
Your experience is much appreciated :thumbsup: The the timing gear (I think it's a Kent) with chain as in above photo was previously used in my mates engine with a tensioner.
I am just about to go down in the workshop to fit the new chain. I will take some pictures of the sprocket teeth then.
Watch this place...
Edited by MiNiKiN, 16 December 2022 - 04:32 PM.
#15 MiNiKiN
MiNiKiN
  • 191 posts
Posted 16 December 2022 - 04:35 PM
Well with that slack we are talking a couple of degrees in "variable timing" - does not make much sense correctly timing it yet. But I have set it to 104° (as per K. Calvers advice to set it 2° early, when measuring on the push rods) - might correct that to 106°.
The sprockets are aligned of course - not with shims, as I had to grind 0.3mm off to get it in line.
Edited by MiNiKiN, 16 December 2022 - 04:35 PM.
