![Photo](https://secure.gravatar.com/avatar/2650e0673baf1fb41e830580ea8ebffa?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
Weird Tapping Noise When Clutch Is Pressed Down
Posted 07 December 2022 - 06:43 PM
Thanks.
Posted 07 December 2022 - 07:46 PM
How have you set the throw out stop nuts? There is much incorrect info out there.
oh and a sound recording would help.
Edited by nicklouse, 07 December 2022 - 07:57 PM.
Posted 07 December 2022 - 11:15 PM
Did you check the thrust clearance sometimes called crank end float?
Edited by T.Harper, 07 December 2022 - 11:21 PM.
Posted 08 December 2022 - 03:48 AM
Posted 08 December 2022 - 10:54 AM
Posted 08 December 2022 - 11:43 AM
Thanks for the help the thrust washers was 100% fitted right. I set the bolt as close to to the clutch arm as possible and untightened half a turn however i didnt adjust the 2 big bolts on the side of the clutch housing because a mechanic told me they are already set good.when I press the clutch there's still a bit of clearance between the nuts and the clutch housing which means its setup good.
What was your thrust clearance on the engine?
Posted 08 December 2022 - 04:06 PM
Posted 08 December 2022 - 08:08 PM
Wrong.
you press the clutch pedal or lever the arm out. Wind the nuts up to the cover. Release arm the wind the nut in (tighten) one flat. Then lock.
you are over pressing the thrust washer now.
9A899D91-4C24-424E-9DBA-7489CC779161.png 188.73K
2 downloads
Edited by nicklouse, 08 December 2022 - 08:54 PM.
Posted 09 December 2022 - 07:10 AM
Posted 09 December 2022 - 08:49 AM
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 ![]() |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 ![]() |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 ![]() |
