Pro's And Con's - Air Filters
9 replies to this topic
#1 Ben Jones
Ben Jones
    Starting My Mini Up
  • 2 posts
Posted 24 November 2022 - 01:51 PM
Hi all
I am looking at replacing my air filter, in my 998 - HS4 SU
Looking at a K&N, Fletcher or Med Engineering.
Both a similar price (K&N & Med ) Fletcher significantly cheaper but does anyone have a preference?
I like the sound of the K&N, but it might be a little loud on a long trip, but I'm also not sure how loud the Med Eng one is/gets?
The Med eng filters seems to flow well and looks nice, possibly better than K&N in all regards, but can anyone advise on the noise comparison?
Let me know what you use instead?
#2 nicklouse
  • 18,574 posts
Posted 24 November 2022 - 03:00 PM
A KN element in the original housing.
#3 KTS
KTS
  • 2,420 posts
Posted 24 November 2022 - 03:01 PM
if you haven't already seen this, worth a read :
https://www.calverst...air-filtration/
#4 andyapanel
andyapanel
  • 623 posts
Posted 24 November 2022 - 05:00 PM
K+N in the original housing with some 3/4" holes drilled in the base of the airbox.
#5 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 24 November 2022 - 05:49 PM
This, especially on a stage one kit equipped mini
#6 Ben Jones
Ben Jones
    Starting My Mini Up
  • 2 posts
Posted 24 November 2022 - 07:50 PM
Thanks for the answers.
Has no one any comments on the Med Engineering filter?
#7 Lplus
Lplus
  • 894 posts
Still likely to need a richer needle.
#8 Steam
Steam
  • 756 posts
  • Local Club: Victorian Mini Club
Posted 25 November 2022 - 01:43 AM
Standard paper filter in the original housing will give the best filtration and thus prevent a dusted engine.
You are unlikely to notice any increase inperformance anyway.
After market filters are designed to trap car owners not dirt.
Edited by Steam, 25 November 2022 - 01:45 AM.
#9 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 25 November 2022 - 06:14 AM
I put a KN cone on my 998/HS4 for a bit of fun. It made a cool noise but I didn’t find it annoying on long trips.
I checked before and after with an afr gauge and in my particular setup it didn’t make any difference (previously I had a KN element in the std airbox). The filter area of a KN filter in the stock HS4 airbox is pretty huge and wouldn’t be a restriction on a 998
#10 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 25 November 2022 - 08:47 AM
I put a K&N element in mine, simply because I can use it again, and again, and again. Parts availability, even for an air filter, is challenging in my country. Yes you can order from Minispares, but not worth it for just one filter. K&N is well known and have enough parts here (including the cleaner solution) to be more cost effective.
