How To Build A Cyclecar
83 replies to this topic
#61 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 14 August 2023 - 09:23 AM
That fire extinguisher looks incredibile,. ..Brilliant candidate for a  fuel tank, those rivets and brass fittings will suit this really well.
I love that you're going to have crack (definitely no pun intended) at casting your own parts too! looking forward to that section.
#62 JDImini
JDImini
  • 679 posts
Posted 14 August 2023 - 08:44 PM
Hi Retro_10s, I'm making the patterns but don't have the capabilities to do my own casting, so I've found a local foundry in West Molesey
#63 nicklouse
  • 18,562 posts
Posted 14 August 2023 - 08:47 PM
Loving this thread. Only just come to it from your FEA question.
#64 JDImini
JDImini
  • 679 posts
Posted 21 August 2023 - 08:28 PM
Not a huge amount of progress this weekend, just filling and smoothing the patterns and no photos
#65 JDImini
JDImini
  • 679 posts
Posted 27 August 2023 - 07:49 PM
and a bit more of the same this weekend
Attached File  steering hub filler.jpg   101.48K   0 downloads
Attached File  steering hub primer 2.jpg   94.66K   1 downloads
Attached File  steering hub primer 1.jpg   99.89K   0 downloads
thanks for looking
cheers Darren
#66 JDImini
JDImini
  • 679 posts
Posted 28 August 2023 - 07:59 PM
And a bit of painting
Attached File  IMG_9699.jpg   117.39K   0 downloads
Attached File  IMG_9698.jpg   146.52K   0 downloads
And then dropped back on to making the armour plating which can just be seen between the leaf springs and ash frame
Attached File  IMG_9701.jpg   145.79K   0 downloads
#67 johnR
johnR
  • 2,296 posts
Posted 07 September 2023 - 01:22 PM
Not much progress this weekend, although I did manage to get out to pick up some metal for the armour plating during the week from a great local company Rudgewick Metals
I started cutting and drilling the armour plating
I also need to thank Jack Kerr a young local blacksmith - JK Forge for helping shape the thicker steelwork
Armour plating - are changing it into a tank or looking to make a roadtrip to Ukraine?
#68 JDImini
JDImini
  • 679 posts
Posted 08 October 2023 - 07:40 PM
Not had much time over the last month.
This weekend has been "drilling it round when it aught to be square" - a bad misquote from Bernard Cribbins "Hole in the ground"
These are washers that need square holes for the bolts
Attached File  square plating.jpg   178.57K   0 downloads
#69 JDImini
JDImini
  • 679 posts
Posted 16 November 2023 - 09:05 PM
Had a delivery today from the foundry, fingers crossed the the patterns I made have worked and the ductile iron castings will be strong enough. I'm really please how they look
Attached File  IMG_9926.jpg   122.91K   0 downloads
Attached File  IMG_9927.jpg   124.11K   0 downloads
#70 Designer
Designer
  • 578 posts
  • Local Club: LSMOC
Posted 17 November 2023 - 06:58 AM
Looking amazing, have missed reading this project. Interesting that you painted the patterns before sending them to the foundry, any specific reason for doing so. Just to highlight well deserved pride in a great job maybe :D ?
#71 JDImini
JDImini
  • 679 posts
Posted 17 November 2023 - 09:18 PM
Thank you, I was pleased with how the pattern came out, just thought having a smooth finish would be better to release the pattern from the sand.
#72 JDImini
JDImini
  • 679 posts
Posted 17 November 2023 - 09:29 PM
This is who I used for the castings, very please with the results and comms with Nick
http://www.fbullettandco.co.uk/
#73 Designer
Designer
  • 578 posts
  • Local Club: LSMOC
Posted 06 March 2024 - 09:01 AM
HI,
How is this fantastic project progressing, any further updates?
#74 JDImini
JDImini
  • 679 posts
Posted 07 March 2024 - 09:10 PM
HI,
Hi, Thanks for the message, unfortunately no progress on this project, just waiting for the weather to pick up as it's an outside job and need some headspace to work out what I do with the castings.
Cheers Darren
#75 JDImini
JDImini
  • 679 posts
Posted 07 May 2024 - 08:38 PM
At last starting to surface after what has seemed like a long winter. One of my next tasks will be welding the front suspension mounts so I've just finished off a faux riveted steel welding screen to protect the cars in the garage when I start welding. I thought it would be a quick job but estimating is clearly not a strong point of mine. It's finished, took me longer and cost more than if I bought a screen
Attached File  faux riveted steel 1.jpg   156.34K   2 downloads
Attached File  faux riveted steel 2.jpg   120.93K   0 downloads
