![Photo](https://secure.gravatar.com/avatar/cec9e3e8cc94273471c0ad7646a8e024?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
Posted 07 November 2022 - 03:30 PM
Posted 07 November 2022 - 03:53 PM
Posted 07 November 2022 - 04:03 PM
Edited by Midas Mk1, 07 November 2022 - 05:09 PM.
Posted 07 November 2022 - 08:38 PM
Either in 4th gear or you don’t understand the principle of an open diff.
Your quite correct I don’t understand the principle, car now on the ground, when lifting the gear stick and backwards towards my knee the car still goes forward, and it doesn’t feel like 4th but it could be, got a mechanic coming int morning so he will advise.
Posted 07 November 2022 - 08:40 PM
thanks that reassuring.Explain. What you say is not actually possible in any way.
Posted 07 November 2022 - 10:14 PM
in theory though just lifting the stick and moving it the right way doesn't necessarily dictate that you're in reverse
lifting the stick just means you can clear a little ridge in the gear selector box it's not directly related to the gearbox itself
could just be something is loose or otherwise not allowing the gear selector to move far enough
the point about the standard open diff (not limited slip) is that you turn one wheel and the other turns in the opposite direction
Edited by stuart bowes, 07 November 2022 - 10:19 PM.
Posted 07 November 2022 - 10:41 PM
So had gearbox rebuilt, jacked one wheel off ground to try gearbox and clutch are working ok, when in reverse the wheels drive forward! Any ideas on why? Thanks
Thats exactly what should happen with one wheel jacked up. Jack up both and they will turn in the right direction.
Posted 07 November 2022 - 11:29 PM
is that true? if that was the case, if one wheel was stuck in mud for example, it would spin backwards, and that's not the case surely
besides it sounds more like the problem is just not getting into reverse properly, probably simplest first thing to try is winding the reversing light switch out a bit to allow a little more movement?
..car now on the ground, when lifting the gear stick and backwards towards my knee the car still goes forward..
Edited by stuart bowes, 08 November 2022 - 12:41 AM.
Posted 08 November 2022 - 04:38 AM
Only a guess here but I think the Shifting Shaft in the Gear Shifter itself has rotated 1800 from how it should be orientated.
If you remove the Gearstick and look in the Shifter Housing, the Hole in the Eye should be lower the the Shaft.
If you find it's higher than the Shaft, then pop the Roll Pin back out of the Coupling (at the back of the gearbox), rotate the Shaft 1800, and refit the Roll Pin. I've made the rotating of the Shaft sound easy here, you may in fact also need to remove the Reverse Light Switch and jiggle the Shaft about a bit to allow it to rotate.
Posted 08 November 2022 - 11:02 PM
Sorry my mistake, was thinking with both wheels up in the air and car in gear , turning one wheel makes the other go backwards.
Posted 09 November 2022 - 11:41 AM
Yes and with one wheel on the ground the one in the air will turn at twice the speed in normal direction when powered from the gearbox.
Posted 09 November 2022 - 12:10 PM
I was once on the last stage of a "Motoring News" somewhere on O/S 147, when the CV 'popped' on full lock.
I was able to force the handle of the ratchet from the socket set, through the diff coupling, and although it ruined the stub axle, I finished on one wheel drive.
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 ![]() |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 ![]() |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 ![]() |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 ![]() |
