Ado 16 / Mg1100 - Poor Running
engine
8 replies to this topic
#1 minimikej
minimikej
  • 347 posts
Posted 02 November 2022 - 02:44 PM
Hi,
Almost embarrassed to ask here, I'm sure I would have sorted this out in 5 minutes 30 years ago.
My blue Mk1 (rebuild here: https://www.theminif...1-mini-rebuild/) is currently fitted with a used but apparently rebuilt ADO16 MG1098 unit.
I cannot get the engine running properly. The engine bogs down on full throttle, sometimes pops back when cold. At full throttle uphill will be fine for about 10 seconds and then start to misfire.
Initially I was on a twin 1.25" HS2 setup, but ditched these because I didn't have the correct manifold, or air filters, or heat shields, to sit well with the LCB manifold.
Replaced with a brand new old stock HIF38, from one of the economy metros.
I blanked off the lean running pipe as described elsewhere.
Breather inlet capped off as described elsewhere.
New K&N conical filter with brand new AAU needle
New minispares BAU1962 distributor: https://minispares.c...cs/BAU1962.aspx
New Lucas Gold 12v coil, non-ballasted.
Vacuum hose is connected.
New leads
New N5YC plugs
Can't hear any vacuum leaks on inlet using small hose to ear technique.
Set timing using adjustable strobe to 12 degrees BTDC, but have experimented with timings all the way from about 20 degrees advance to zero.
Setup idle emissions using old Gunsons Gastester, 3.5%CO at idle.
Compression across all cylinders is good and similar across all pots, can't remember the exact figure.
After a hard run up the local test hill, the plugs are a light brown and oil-free.
Sounds okay when it's idle or part throttle, no misfire. Plant your foot down though and it bogs, may pop back through carb.
I've tried disconnecting and plugging the vacuum advance to see if it's over advanced at idle, doesn't seem to help.
What's left to check? Cam timing??
Mike
Edited by minimikej, 02 November 2022 - 02:45 PM.
#2 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 02 November 2022 - 03:08 PM
Backfiring through the carb is usually something that indicates a lean mixture, and although i don't know the exact profile of the AAU needle you have fitted, It is incredibly rare for a needle to fuel correctly across the entire drivable RPM range straight out of the box,.. They all need optimising by hand, to the exact set-up of the car.
Have you tried using the choke when driving uphill to see if it affects the bogging down you're experiencing?
#3 cal844
cal844
  • 9,606 posts
  • Local Club: TFMOC
Posted 02 November 2022 - 03:27 PM
Get the needle and parts optimised by someone who is AC Dodd trained, worth the money
#4 minimikej
minimikej
  • 347 posts
Posted 02 November 2022 - 03:42 PM
I have, no obvious difference.
#5 minimikej
minimikej
  • 347 posts
Posted 02 November 2022 - 03:46 PM
Forgot to add,
The dashpot oil is full, 15/40.
Fuel pump is new, it's s solid-state version of the SU electric pump.
#6 minimikej
minimikej
  • 347 posts
Posted 02 November 2022 - 05:16 PM
I will definitely consider getting it professionally tuned, it's just that it feels like there is a problem to be fixed before that can happen, like I'm not even in the right ball-park and the tuner would be spending their time diagnosing a fault rather than actually tuning.
#7 cal844
cal844
  • 9,606 posts
  • Local Club: TFMOC
Posted 02 November 2022 - 05:25 PM
Try a heavier grade oil, 20w50 engine oil as a test
#8 sonscar
sonscar
  • 2,934 posts
Posted 02 November 2022 - 07:36 PM
Ditch the cone filter and put a standard airbox back.If the cone filter is important to you then fit a stub stack.Is the gasket for the filter the correct way round?Just a few thoughts,Steve..
#9 Lplus
Lplus
  • 824 posts
Posted 03 November 2022 - 10:06 AM
Not sure why the breather inlet is blocked off. SU fitted a breather for a reason.  I'd try with the breather open. Blocking the breather means the pressure above the fuel in the float bowl is either the reduced pressure inside the air filter or even lower.  This lack of pressure will affect the fuel flow through the jet, and the higher the air flow the lower the pressure.
If that doesn't help I'd try an ABD needle and if that didn't help enough try an AAM needle.  I realise that's yet another £15 or so for each needle but if it helps it points you in the right direction.  Having tried an 12G 295( skimmed to give standard compression) on an 1100 engine , the AAM needle in an HS4 with K&N filter solved the misfire/bogging down problem I had.
