Decent Baulk Rings ?
9 replies to this topic
#1 Spider
  • 14,838 posts
Posted 02 November 2022 - 08:30 AM
Where can I get decent Baulk Rings for road use ?
Only interested in ones that;-
      i) don't break, and
     ii) if purchased, will actually be delivered
This one did less than 10 km
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 02 November 2022 - 08:35 AM
MiniSport competition ones are good, but eye-wateringly expensive, I believe made by Quaife. I use these in my rally car now and not had a problem (so far)
Classic Minis Japan also do some, not sure how good they are though but I would suspect decent.
Edited by GraemeC, 02 November 2022 - 10:36 AM.
#3 Mini Waco
Mini Waco
  • 438 posts
Posted 02 November 2022 - 10:53 AM
      i) don't break, and
MED baulk rings
#4 pete l
pete l
  • 1,368 posts
Posted 02 November 2022 - 02:48 PM
Talk to john guessworks, if anyone knows of good baulk rings, it's him.
#5 Shooter63
Shooter63
  • 1,024 posts
Posted 02 November 2022 - 06:58 PM
You weren't kidding when you said expensive, £78 a pop, kin ell.
Shooter
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 02 November 2022 - 08:13 PM
They are. But when you have them in your hands you can tell they are streets apart and have been thought about - not just copies of the same mistakes.
The ears are offset from the grooves, meaning the heat treatment hasn’t made them brittle at the thinnest points. Each one is hand engraved with a batch code which gives confidence in some level of quality inspection process.
For long enough they never actually sold them to Joe Bloggs, you could only get them ‘under the counter’ if you were a MiniSport Cup competitor. I believe Swiftune use them too (no doubt direct from Quaife).
I’ll admit I only use them on 1st & 2nd, using selected good used ones on 3rd & 4th. But £80 a pop is better than not finishing an event that has cost much more to enter! I’ve been running the current pair for over 2 years with no issue. The friction surface on the gears also lasts much better.
Edited by GraemeC, 02 November 2022 - 08:19 PM.
#7 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 04 November 2022 - 09:58 AM
I've had 2 sets of the MS evo ones and all but 2 of them were oval. I'm having to rebuild the gearbox on the turbo now and using guessworks oem ones. Just hope it works!
#8 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 04 November 2022 - 11:45 PM
Classic marketing, these and their pumps i’ve had less than good times with .
#9 Spider
  • 14,838 posts
Posted 05 November 2022 - 11:40 PM
Many thanks for the suggestions guys, all taken on board.
Simon from Mini Spares has kindly offered to send me a set from their latest batch.
Sorry to to read of issues others have also had.
#10 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 06 November 2022 - 05:57 PM
John @ Guessworks is your man Chris, he only uses the best parts he can get...
http://guess-works.com/
P/N 22G2033
However it states on the website that they are closed til the 14th of November.
Hope this helps
Edited by cal844, 06 November 2022 - 06:00 PM.
