Another Engine Number Mystery
engine
9 replies to this topic
#1 Domiracer
Domiracer
    Just On Tickover
  • 5 posts
Posted 24 October 2022 - 05:29 PM
Joined the forum as I am starting the restoration of a 70 MkIII (per V5).
Also acquired this motor....looks like a run of the mill 1275 except for the number.....maybe a rebuilder tag?
#2 beardylondon
beardylondon
  • 1,468 posts
Posted 24 October 2022 - 06:54 PM
Post the number, then someone should be able to help?
#3 Domiracer
Domiracer
    Just On Tickover
  • 5 posts
Posted 24 October 2022 - 08:28 PM
Sorry folks, inserted pics in the post but apparently that does not work. Need to figure how to attach or insert a pic.
#4 nicklouse
  • 18,402 posts
Posted 24 October 2022 - 08:35 PM
Hist it on Imgur and link/insert.
or just type out the number for now.
#5 Domiracer
Domiracer
    Just On Tickover
  • 5 posts
Posted 24 October 2022 - 08:46 PM
Will post the pics shortly but for now.......number is V4130 302512.....typical stamped plate riveted to the deck face.
Attached File  Mini Motor Number.jpg   38.3K   28 downloadsAttached File  Mini Motor.jpg   37.02K   31 downloads
Edited by Domiracer, 24 October 2022 - 09:10 PM.
#6 nicklouse
  • 18,402 posts
Posted 24 October 2022 - 09:39 PM
Mmm looks like a 1275 A+ out of a Metro.  As for the numbering. No idea.
#7 Domiracer
Domiracer
    Just On Tickover
  • 5 posts
Posted 24 October 2022 - 09:53 PM
Was able to remove the plate......"STD M" stamped on the deck underneath....
#8 Ethel
  • 25,827 posts
Posted 24 October 2022 - 11:14 PM
Standard Metro? Don't think there'd be anything under the plate, so perhaps it's been salvage or a non factory refurb?
The thermostat housing & clutch end breather are Metro & the one on the timing chain cover looks like it might be too. Metros are a round can that fouls the fan in a Mini, so the Mini version has a flat added.
#9 Domiracer
Domiracer
    Just On Tickover
  • 5 posts
Posted 25 October 2022 - 09:55 AM
Thanks for the information, not sure how a Metro lump ended up in a barn in Maine USA but that’s another mystery. At least worth pulling the head and differential to see what spec they are and if if serviceable. If all is good will rebuild and use in place of the 998 I currently have.
#10 Ethel
  • 25,827 posts
Posted 25 October 2022 - 11:29 AM
Inside a Mini probably.
It was a very common thing to do over here. Metros tended to make it in to the breakers' yards sooner and there were a lot of 1275 Metros & older 998 Minis.
Would it have needed an engine number to be imported? Perhaps it was just a convenient bit of metal with stamped code that looked passable?
The engine mountings are different, so it has anything that matches your Mini's on the radiator end that'll be the case.
They all have holes for both mountings on the clutch end so you might be able to tell which have been used - Metro used the triangle of 3 bolt holes about 1/2 way up the back of the transfer case.
