Metro Turbo Oil Pipe
Posted 14 October 2022 - 04:08 PM
Posted 15 October 2022 - 09:29 AM
You mean the Vacuum pipe?
pipe and ends readily available form your favorite MiniSpares shop.
Posted 15 October 2022 - 10:48 AM
Posted 15 October 2022 - 10:52 AM
Edited by Nastyhank, 15 October 2022 - 10:53 AM.
Posted 15 October 2022 - 10:56 AM
That looks like either the servo vacuum pipe or the oil pipe that runs to the filter across the block. Neither have anything to do with the Dizzy.
both are NLA new but there are alternatives.
Posted 15 October 2022 - 11:30 AM
It's the oil feed to the turbo. It connects to the engine where the oil pressure switch does with a banjo bolt.
It's only likely to line up if you're using a complete Metty Turbo setup, with a T3 turbo. Many replaced it with a braided hose
http://minispares.co...|Back to search
You could probably put your own together for less
Posted 16 October 2022 - 10:48 AM
