1.8T Audi Swap Rwd
53 replies to this topic
#1 hotwheels
hotwheels
  • 195 posts
Posted 11 October 2022 - 10:43 PM
Its been sometime since ive been on here, and wanted to share a recent project i started back in May. basically taking the Running gear from an Audi 1.8T. so far ive made some great progress. engine and trans are now mounted and im using a 03 miata rear subframe assembly. A bunch of hiccups started along the way as expected but pretty sure i have sorted most of them. as of recently, i just sorted out the steering rack location in my latest video, feel free to check it out and leave opinions along the way! Cheers from across the Big Pond  :proud:
https://youtu.be/UzvMEARQtBE
Edited by hotwheels, 11 October 2022 - 10:52 PM.
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 12 October 2022 - 04:07 PM
Loving this. Subscribed..
#3 hotwheels
hotwheels
  • 195 posts
Posted 12 October 2022 - 08:25 PM
Thank you Mike!! Really appreciate it!πŸ™πŸ»
#4 Tones61
Tones61
  • 426 posts
Posted 13 October 2022 - 01:23 PM
Subscribed dude ;-)
#5 hotwheels
hotwheels
  • 195 posts
Posted 13 October 2022 - 04:10 PM
My man! Thank you TonyπŸ™πŸ»πŸ™πŸ»πŸ˜‰
#6 hotwheels
hotwheels
  • 195 posts
Posted 16 October 2022 - 07:43 PM
While i was moving a head. I realized upon fitting the steering knuckles that they simply werent going to line up with the new lowered steering rack tie rod ends. A bunch of head scratching and caffeine but think we solved the issue.
#7 hotwheels
hotwheels
  • 195 posts
Posted 23 October 2022 - 04:21 AM
Some new goodies have arrived and the car is now on all four wheels. Sitting a little low to the ground, ill have some fiddling to doo. Other than that, it feels good to see her sitting finally
#8 hotwheels
hotwheels
  • 195 posts
Posted 24 October 2022 - 12:48 AM
#9 KTS
KTS
  • 2,392 posts
Posted 24 October 2022 - 09:37 AM
coming together nicely - great work !
worth pointing out that signing up as a TMF member (..only Β£5 a year..) means you can get a 7.5% discount on your minispares orders
https://www.theminif...es-75-discount/
#10 hotwheels
hotwheels
  • 195 posts
Posted 24 October 2022 - 10:07 AM
Ahh that would helpful for sure, ill check into it after work. Appreciate the info. Thanks KTS!!
#11 R1mini
R1mini
  • 1,386 posts
Posted 25 October 2022 - 04:20 PM
It may of been mentioned in the videos somewhere but will this end up as rear 2 wheel drive
David
#12 hotwheels
hotwheels
  • 195 posts
Posted 26 October 2022 - 12:26 PM
Absolutely!! I welded the planetary gears in the trans a
So there will always be power to the rear drive train. Simply just bot using the front wheel drive. I slim down the flanges and away with that. Also the front axles would never line up anyways haha. But yeaa. I want to just make a rwd donut machine thats fun in the streets and mayb possibly try and drift this thing πŸ˜…
#13 hotwheels
hotwheels
  • 195 posts
Posted 07 November 2022 - 01:17 PM
More Steering Shananagans
#14 Maccmike8
Maccmike8
  • 1,101 posts
Posted 07 November 2022 - 08:27 PM
Great work, I have fond memories of making my own suspension on a kit car, bottom and top wishbone locations and angles the lot, no bump steer or anything and worked really well.
Are you happy welding those cast arms?
#15 hotwheels
hotwheels
  • 195 posts
Posted 07 November 2022 - 09:50 PM
thats awesome man!! i will still have to feddle with bump steer but i think im going in the right direction anyways hahah. and i mean i feel pretty confident in the welds, the only thing is, i didnt pre heat the cast first but its a little late for that now uggg. back in 2009, i had a lifted jeep with big tires and i fitted bigger dana 60 axles underneath. i welded one of the control arm mounts to the front differential casing which was cast and it held really nice for a good 2 years until one snowy day i was coming around a tight corner and some guy cut me off which forced me to drive into someones front yard where there was a giant snow bank. i hit the bank and the mount snapped off the casing. that was stick welded also but yeah that was the only time i had a weld fail on mee. in this mini case, mayb i could add metal bits around it for insurance??
