Question About The Hub Castle Nut
16 replies to this topic
#1 mattaebersold
mattaebersold
  • 42 posts
Posted 10 October 2022 - 09:16 PM
Question about the hub and castle nut.
When I tighten the nut, it goes past the hole in the shaft. Then, sticking a cotter pin in there doesn't go in between the cutouts in the nut. My issue started when the nut was working it's way loose as I drove for awhile, shearing off the cotter pin. Yikes.
So I want to solve this once and for all... I have a few thoughts, please help let me know which is the best option...
1. I could get a washer at the correct size, so that when I apply all the torque to the nut, then the hole is within the grooves. I question the type of washer material, like something that's strong enough to withstand the torque, as well as a type of metal that wont corrode.
2. I torque the nut correctly, and then just put a cotter pin in even though it's clearing the nut. At least that would stop it from walking loose?
3. ??? Something I'm not thinking of? A root cause somewhere else?
#2 nicklouse
  • 18,583 posts
Posted 10 October 2022 - 09:27 PM
First thing would be to check the taper washer for wear. Then follow the manual. Tighten to torque then keep going untill you can align the holes for a pin to be fitted.
#3 Spider
  • 14,848 posts
Posted 11 October 2022 - 04:12 AM
Sorry, but your CV is now karput.
#4 sonscar
sonscar
  • 2,997 posts
Posted 11 October 2022 - 08:14 AM
I agree,thread is goosed.It is done very tight.Steve..
#5 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 11 October 2022 - 09:24 AM
That CV joint needs replacing, the threads have stripped and it would be wise to now replace the other side as a precaution.
#6 Ethel
  • 25,922 posts
Posted 11 October 2022 - 10:02 AM
It's a split pin, not a cotter, just to save confusion if you're searching for replacements.
As Spider says something else is amiss if it's unscrewing & shearing the pin. The pin's just a failsafe & should never be loaded in usual conditions.
#7 GraemeC
GraemeC
  • 7,438 posts
Posted 11 October 2022 - 10:15 AM
He's in the USof A though Eth, where our split pin is their cotter pin.
#8 andyapanel
andyapanel
  • 624 posts
Posted 11 October 2022 - 11:46 AM
I would change the bearings, too.
You will need a Haynes which takes you through the process of tightening up the hub nut.
Good luck; if its your first go, take it slowly, follow the steps and it will be fine. Make sure you have the correct sized split pins and the big washer to load the bearings.
#9 sonscar
sonscar
  • 2,997 posts
Posted 11 October 2022 - 11:48 AM
When I had a similar happening the hub,joint washer and nut stacked up tolerances so that it would undo no matter how tight it was.Renewed them all with new bearings and fixed it.Steve..
#10 Richard e
Richard e
  • 103 posts
Posted 11 October 2022 - 03:39 PM
Don’t you need to use a flat washer to tighten the nut to the required torque and then replace the tapered washer re torque and fit the split pin (after you have replaced the cv joint due the threads being stripped)
#11 mattaebersold
mattaebersold
  • 42 posts
Posted 11 October 2022 - 03:44 PM
Interesting. I never thought about wear on the tapered washer. I will get new ones for both sides.
And many of you are saying the CV is bad, kaput, etc. Can you let me know how that relates to the problem of the nut screwing down too far to clear the hole for the pin?
- are the actual threads compromised somehow? Like they won't hold the nut torqued down?
- is there something in the CV/axles where when it wears, and it's 'bad', then the shaft has play or something, and sticks out too far?
I see the logic in the idea that the tapered washer has worn down, but I don't see the immediate logic in the CV's are just 'bad'
#12 nicklouse
  • 18,583 posts
Posted 11 October 2022 - 04:02 PM
What do you mean by this. It does not really make sense as you torque the nut then moving on till the hole lines up. You saying screwing down to clear is not clear.
re the CVs and the hubs. If the bearings have been run with the nut lose they can spin. Then the hub and cv are normally out of tolerance and need replacing.
#13 Lplus
Lplus
  • 894 posts
Posted 11 October 2022 - 05:06 PM
Looking at your photo it almost seems as if the threaded section has stretched and distorted the threads - hat might cause the nut castellations to go beyond the hole. But there's other possible reasons such as:-  worn hub where the outer bearing races seat; missing or worn spacer between the two inner bearing races;  worn bearing races themselves; worn rollers themselves.
The fact the nut keeps loosening suggests something keeps wearing quickly within the hub/bearing system and you should dismantle the whole lot to find out.
#14 bikewiz
bikewiz
  • 320 posts
  • Local Club: NEMO
Posted 11 October 2022 - 05:44 PM
Once you've replaced the CV with new I've found the 12 slot castle nut from Classic Minis Japan and the tapered washer from KAD are worth using.
https://kentautodeve...730d3426d&_ss=r
https://classicminis...lot-castle-nut/
#15 Spider
  • 14,848 posts
Posted 11 October 2022 - 08:24 PM
I can see the thread on the CV is very badly damaged. This is a safety critical item.
When the nut is done up, it's torqued according to the CV you have, then tightened further to align the slots in the nut with the hole for the split pin.
This is not a complete guide, but you might find it enlightening;-
https://www.theminif...wheel-bearings/
