Epoxy Over Zinc Primer
8 replies to this topic
#1 pete l
pete l
  • 1,368 posts
Posted 07 October 2022 - 08:22 AM
Hi all,
I'm removing all the paint on the inside floor of my MPI to remove and treat the spider track rust thats under the paint, as I'm going along I'm spraying zinc primer to protect the bare metal.
This primer is very soft and scratches off very easily.
Do I have to remove it before painting the floor with 2K epoxy primer ?
All advice welcome :-)
Pete.
#2 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 07 October 2022 - 11:49 AM
Not sure what the official answer is - however mine was zine primed in bare metal corners and joins (pumped in in some cases) then the entire body was epoxy primed. No reactions!
#3 pete l
pete l
  • 1,368 posts
Posted 07 October 2022 - 01:24 PM
Thanks Steve,
I'm more worried about it peeling, the zinc primer doesn't seem to be very tough.
I've just found a test on the internet, using sticky tape to see if it peels off.
#4 Gaz66
Gaz66
  • 894 posts
Posted 07 October 2022 - 01:49 PM
Does it peel off?
Im using zinc primer to temporarily cover things as I weld so when I get to the painting stage its somewhere near.
#5 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 07 October 2022 - 03:45 PM
Does it peel off?
Mine never did. I sand blasted tight areas and poured the primer in.
#6 Vanman20
Vanman20
  • 274 posts
Posted 07 October 2022 - 03:58 PM
Epoxy over bare metal is what most restorers do.If it were me I'd remove the zinc,especially as it hasn't adhered very well by the sound of it
Novol do a temporary primer that's also weld thru https://refinishsyst...24aAksoEALw_wcB
#7 Tupers
Tupers
  • 4,143 posts
Posted 07 October 2022 - 06:38 PM
What zinc primer are you using and how are you preparing the metal before painting it?
I use ZINC-182 quite often and never had problems with it scratching off of a surface sanded with 240 grit.
#8 sonscar
sonscar
  • 2,995 posts
Posted 07 October 2022 - 08:42 PM
Whatever paint system you use it only sticks as good or bad as the coats underneath it.If suspect now is the time to remove it.Steve..
#9 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 07 October 2022 - 09:23 PM
I have used the same stuff as Tupers on The Red One and all I did was degreased, scuffed and then brushed on. ( that’s what Paul had at the time) and it never reacted, scraped off etc.
I used UPol Zinc Rich primer on Paddy, again same method as The Red One and applied Epoxy over that with no issues. The metal has to be squeaky clean, keyed properly then happy days.
If in any doubt about the primer, remove it completely. No point in hoping it will come good.
