7.9" Calipers And Wheel Fitting
14 replies to this topic
#1 Apdiliars250
Apdiliars250
  • 74 posts
Posted 05 October 2022 - 08:17 AM
This has been discussed loads of times I have searched but can't really find a answer.
With the mini sport 7.9" 4 pot calipers they say some 10" wheels fit. Is there a way to tell before I buy the wheels like certain off set wheel?
The alloys I want aree OS4 Turbo Alloy Wheel and are ET-7
Edited by Apdiliars250, 05 October 2022 - 08:18 AM.
#2 sonscar
sonscar
  • 2,921 posts
Posted 05 October 2022 - 08:38 AM
There is probably more to consider than the offset,casting thickness,spoke? design,shape of inside the wheel,Steve..
#3 71Pickup
71Pickup
  • 94 posts
Posted 05 October 2022 - 08:13 PM
Any reason you want the 7.9s? 7.5s will work just as well and give you unlimited choice of 10” wheels
M
#4 Apdiliars250
Apdiliars250
  • 74 posts
Posted 05 October 2022 - 09:51 PM
I would of thought 7.9" would be better than 7.5" being slightly bigger and also vented discs.
M
#5 nicklouse
  • 18,366 posts
Posted 05 October 2022 - 09:57 PM
M
 Vented is not always better as cold pads are crap. 7.5 with the carbon pads that MiniSpares do will give all the braking you will need on 10s.
#6 nicklouse
  • 18,366 posts
Posted 05 October 2022 - 10:00 PM
 Back to your question. I would ask the seller. If they don’t know I would walk away.
#7 Apdiliars250
Apdiliars250
  • 74 posts
Posted 06 October 2022 - 07:46 AM
They know what wheels what they sell fit but not other makes. 7.5“ looks like the easiest option it's just weird going back to solid discs
#8 71Pickup
71Pickup
  • 94 posts
Posted 07 October 2022 - 07:21 PM
How about vented 7.75 from KAD
https://kentautodeve...ant=55078427015
#9 Cooperman
  • 23,183 posts
Posted 07 October 2022 - 07:30 PM
M
That's what I use on my 1964 rally 'S' and even on very hard events on tarmac, with the carbon-metallic pads and race brake fluid I get no brake fade even when the 7.5" discs are glowing literally red hot.
With a light car like the Mini, it is possible to have brakes which simply don't get warm enough to work. On a road Mini vented discs are really a bit 'overkill'.
#10 bpirie1000
bpirie1000
  • Area Managers
  • 2,279 posts
  • Local Club: Amoc
Posted 05 February 2024 - 09:44 AM
Post revival...
Okay so current build has 7.9 wheels and 4.5x10" minilights.
Fitted all the hubs discs calipers as per the kit provided. All looks good.
Put the wheels on looks magic. Well chuffer...
Gutted...
They appear to rub the rim... annoying... currently putting it down to possible corrosion on the inside of the rim that will be attended to in due course, obviously.
Is there a list of wheels that actually fit underneath these 7.9" calipers?
Thanks.
#11 imack
imack
  • 2,014 posts
Posted 05 February 2024 - 10:06 AM
I'm running KAD 7.9" calipers and vented discs with these 6x10 Minilites.
Edited by imack, 05 February 2024 - 07:51 PM.
#12 coopertaz
coopertaz
  • 739 posts
  • Local Club: a-series-magpies
Posted 05 February 2024 - 10:34 AM
running 10" revolutions on gf's car with minisport 7.9 four pots, rims clear ok but watch out for weights they may catch, someone else in club made me aware of this when he fitted them and had same issue with minilite alloys
#13 Ethel
  • 25,792 posts
Posted 05 February 2024 - 02:01 PM
7.5 inch discs have a smaller inner diameter too. They have a pretty similar piston & pad area to 8.4's.
Pretty sure all the 4 pots are based on the Metro's, so bigger discs give proportionally better leverage (retarding torque) & disc area, affecting warm up & cooling rates.
#14 bpirie1000
bpirie1000
  • Area Managers
  • 2,279 posts
  • Local Club: Amoc
Posted 05 February 2024 - 02:33 PM
What width are you running?
#15 coopertaz
coopertaz
  • 739 posts
Posted 07 February 2024 - 11:00 AM
6 x 12
Edited by coopertaz, 07 February 2024 - 11:00 AM.
