Replacement Shocks On My 98 Mpi
suspension
Best Answer dan1zo , 24 August 2022 - 05:18 PM
Go for Protech (call them direct) softer than Gaz and more selections.... Plus great warranty
Oooooh those Protech ones look so pretty.
Think it might just come down to how much i want to spend.  These and the Gaz ones are a bit more budget friendly bearing in mind i've just spent £500 getting it through an MOT (bloody emissions!).
Go to the full post
11 replies to this topic
#1 dan1zo
dan1zo
  • 52 posts
Posted 23 August 2022 - 02:46 PM
Hey friends
I'm looking to replace the shocks on my mini as it seems the original Koni red ones, the rubber mountings have deteriorated. One on the front and one on the back and making a horrible rattle.
I thought the rubbers could just be replaced, but they seem to be in built and i guess the whole thing needs replacing.
So my question is, should i just replace like for like, or would it be worth using another brand/type.
Minisport seem to have a bigger selection than Minispares.
So is it worth going for Gaz or maybe the Spax Krypton?
If anyone has any experience of setting up or using different ones, that would be great.
Dan
#2 cal844
cal844
  • 9,610 posts
  • Local Club: TFMOC
Posted 23 August 2022 - 04:25 PM
#3 mad4classics
mad4classics
  • 199 posts
Posted 23 August 2022 - 04:38 PM
If you want nice shiny new shock absorbers - that's fine, but the rubbers are available.
They are usually a press fit. I think these are the ones?
Front
https://www.ebay.co....tm/384908824115
Rear
https://www.ebay.co....RoAAOSwJrFijegu
Edited by mad4classics, 23 August 2022 - 04:59 PM.
#4 Steve220
Steve220
  • 5,016 posts
  • Local Club: BMC
Posted 23 August 2022 - 05:05 PM
You can replace the rubbers, they're an OEM part. I'll see if i can dig out the part number
Edited by Steve220, 23 August 2022 - 05:05 PM.
#5 mab01uk
mab01uk
  • 12,370 posts
Posted 23 August 2022 - 05:56 PM
The original Koni red shocks were factory fitted to the MPi Minis because of the heavier 6x13" Sportpack wheels.
#6 coopertaz
coopertaz
  • 771 posts
  • Local Club: a-series-magpies
Posted 24 August 2022 - 10:23 AM
Gaz give decent ride and never had problem, spax and koni always seemed too harsh
#7 dan1zo
dan1zo
  • 52 posts
Posted 24 August 2022 - 01:06 PM
Front
Rear
Interesting, i did try to get the old bushes out of the front, but the metal tube wouldnt come out, it felt like it had barbs on it to keep it in place. Maybe i dont have the tools to be able to press it out? The bush kit on ebay just doesnt look right with the raised rubber edge, or are mine deteriorated so badly the edge is gone?
Mine are no longer red due to a number of resprays where they werent covered up correctly. I do like the idea of shiny new ones.  ;D
Edited by dan1zo, 24 August 2022 - 01:19 PM.
#8 dan1zo
dan1zo
  • 52 posts
Posted 24 August 2022 - 01:11 PM
Would that mean others might not be suitable for the sportspack wheels?
#9 Cooperman
  • 23,225 posts
Posted 24 August 2022 - 03:39 PM
Koni dampers work on a slightly different principle than other dampers. They are softer on 'bump' than on 'rebound'.
Personally I like SPAX and GAZ. They are both easy to adjust and work well on any size of wheel or tyre as the optimum setting is easy to obtain. The price is about right as well.
#10 Lplus
Lplus
  • 849 posts
Posted 24 August 2022 - 04:46 PM
Standard mini shocks from Minispares are softer on bump, as are gaz shocks.
#11 dan1zo
dan1zo
  • 52 posts
Posted 24 August 2022 - 05:00 PM
#12 dan1zo
dan1zo
  • 52 posts
Posted 24 August 2022 - 05:18 PM   Best Answer
Also tagged with one or more of these keywords: suspension
