Cannot Get Into Gear When The Engine Is Running!
19 replies to this topic
#16 sonscar
sonscar
  • 2,995 posts
Posted 14 November 2022 - 06:54 PM
First check,does the pedal press down as normal?no?plunger arm rusted stuck.Yes?does the arm move half inch or more?It is a very simple arrangement and possibilities are few.Steve..
#17 postve
postve
  • 524 posts
Posted 15 November 2022 - 05:44 PM
Thx gents and seems there is a rattling noise when I let the car idle - still does not go into gear - next up, remove flywheel and check primary gear from other feedback I got..Note, I did everything by the book and looks like a failure somewhere, possibly me as confirmed via the starter motor port with pedal depressed cannot turn clutch plate at all??
Oh, can one leave the keyway washer in as impossible for me to remove as doing this job - engine installed
Edited by postve, 15 November 2022 - 05:49 PM.
#18 imack
imack
  • 2,103 posts
Posted 15 November 2022 - 06:06 PM
To remove the flywheel the keyed washer has to be removed.
#19 postve
postve
  • 524 posts
Posted 15 November 2022 - 06:59 PM
Yep I figured thought I would ask anyways
#20 postve
postve
  • 524 posts
Posted 29 June 2023 - 08:04 PM
Hey guys sorry as updated elsewhere but not here - to conclude on my issues
- bolt on my orange diaphragm was loose - user error
- throw out bearing was not adjusted properly - user error
All good and thx again for inputs m8’s
    Bing (1)
