Cannot Get Into Gear When The Engine Is Running!
19 replies to this topic
#1 Dutchy1990
Dutchy1990
  • 15 posts
Posted 10 August 2022 - 03:06 PM
Good Afternoon All,
So i am having an issue getting into any gear when the engine is running, when the engine is off, i can select any gear smoothly.
The car had been sat around for a month or so and before i never had any issues.
I bleed the hydraulics at the slave cylinder last weekend and the issue seemed to resolve itself, however after a week of non running the issue has returned.
I am thinking I have an issue with the master cylinder or slave cylinder but was wondering if there was any sort of test or anything else i can do to determine if this is the issue before i buy a new ones?
Thank you in advance.
#2 sonscar
sonscar
  • 2,995 posts
Posted 10 August 2022 - 03:12 PM
Does the clutch pedal work normally?does the clutch lever on the wok move half an inch or so?,Steve..
#3 Dutchy1990
Dutchy1990
  • 15 posts
Posted 10 August 2022 - 03:26 PM
The clutch pedal travels normally but seems a bit light if that makes sense? When I look at the clutch lever everything seems to be working fine and looks like it is moving about that. I will double check that distance when I get in.
Cheers. Dan.
Edited by Dutchy1990, 10 August 2022 - 03:26 PM.
#4 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 10 August 2022 - 04:06 PM
I would suspect a leaking master or slave cylinder is the problem. You can try pumping the peddle and see if you can get it in gear that way. That would indicate a hydraulic issue.. Sometime once in gear they leak pressure causing the clutch to start to bite after a while of holding the peddle down. I would look up under the dash for sighs of a leak and on the slave cylinder. Hopefully it is the slave cylinder as that is cheaper and easier to fix. I personally don't rely on repair kits anymore after have some earlier failures on them I would just replace the complete component at fault with a new one (much better in the long run)
#5 ac427
ac427
  • 674 posts
Posted 10 August 2022 - 06:58 PM
Is the clutch adjusted properly?
#6 Dutchy1990
Dutchy1990
  • 15 posts
Posted 10 August 2022 - 08:29 PM
Slidehammer - thanks for the advice, I will have a look into those points you have raised.
Ac427 - I can only assume yea as I haven’t touched it since I have got the car a couple of years ago. I guess I am going to have to go through the Haynes manual to check the clutch is adjusted properly.
#7 KTS
KTS
  • 2,420 posts
Posted 10 August 2022 - 10:16 PM
is it possible that the clutch plate has stuck to the flywheel or backplate?
can't remember what you can do to release it, but I'm sure a search will throw up a few suggestions
#8 Andosoft
Andosoft
  • 15 posts
  • Local Club: Nsw
Posted 11 August 2022 - 03:05 AM
I have had the clutch plate stuck to backplate a few times before (moisture during storage effectively had it rusted on). To check if this is the case you can pop the starter motor out, have someone push the pedal in. Looking through from starter, you should be able to see the plate movement and it should be free (i moved mine with a screwdriver to check). I was also able to free it once using a screwdriver and easing it off the plate. Another time i had to remove the diaphragm.
Have since replaced flywheel, clutch plate and resurfaced the backplate. No longer an issue.
#9 Dutchy1990
Dutchy1990
  • 15 posts
Posted 11 August 2022 - 05:15 AM
Thanks for the help!! Home from work tonight now so I will give all this a try at the week! 👍🏻
#10 postve
postve
  • 524 posts
Posted 13 November 2022 - 08:17 AM
Hey Dutchy, So what was the issue ?
#11 viz139
viz139
  • 665 posts
  • Local Club: Irish Mini Owners Club
Posted 13 November 2022 - 12:00 PM
To free a stuck clutch plate start the car in gear with the clutch pedal pressed fully down. Had to do this a few times when car left outside for a long period,much longer than a week. Your problem sounds more  hydraulic.
#12 postve
postve
  • 524 posts
Posted 14 November 2022 - 12:46 PM
Thx Viz as I have same issue but my clutch is basically brand new and only 590km on it, car has been sitting for 6 months as I was doing body work but damn thing will not disengage no matter what I do, trying the - rotate the plate today - see if that is the issue and if so, then what, I just put the damn motor in after swapping out gears and clutch was fine just a month ago before I did the job??? I was testing the car after sitting to avoid just that and after pulling engine and changing gears - no disengagement - and yes I have done all the adjustments, has a new slave etc so truly down to the clutch - any thoughts??
#13 GraemeC
GraemeC
  • 7,438 posts
Posted 14 November 2022 - 02:09 PM
So yours is probably more an assembly issue than a clutch sticking just because it has been sat. Possibly you should start your own thread so that it doesn't distract from the original poster's problem.
#14 postve
postve
  • 524 posts
Posted 14 November 2022 - 02:51 PM
Agreed and this is a pre balanced so not sure how on earth it could be an assembly as nothing has changed since I removed engine and put gears back in - will start a thread but working with MED folks to resolve
Thx Viz
#15 stuart bowes
stuart bowes
  • 2,102 posts
Posted 14 November 2022 - 03:19 PM
I read a Clarkson article once (I know generally he just repairs things with hammers I grant you) but he had an old Alfa with this issue, someone quoted him some daft price
in the end he wedged a broom handle in holding the clutch pedal down and left it overnight, by the morning it had pinged free
couldn't really say if that was adviseable or not
