Hi all,
At some point over the next week I'll be replacing my fuel pump, not because there's any desperate need to do it but simply because this is the original pump from 1988 and I'm getting wary of the additional ethanol in fuels recently. Also, being from an engineering background, I'm acutely aware that rubber can't be relied on to last 34 years at the best of times, ethanol or no ethanol! I really don't want to end up with a sump flooded with petrol.
The replacement pump is a like-for-like mechanical unit, AZX1818 from Minispares.
My problem is, how do I get enough space to pass the old pump out and get the new one in?
I think it's my exhaust manifold that's causing the problem, it's the Maniflow unit from the Minispares Stage 1 kit and there isn't enough clearance to pass the pump through.
I suppose an obvious solution would be to detach the exhaust manifold to give it clearance to push down a bit, but I only replaced the manifold gasket a couple of weeks back and I hate messing with gaskets once I've got them sealed successfully.
fuel pump.jpg 38.12K
3 downloads
Two possibilities occur to me:
- is it possible to pass the new pump into place from below the car, by reaching round the CV joint?
- will removing the red breather canister give enough clearance, and is it straightforward to remove? I tried feeling for bolts but couldn't feel any. If I do remove the canister, will it need a fresh gasket?
Loads of forum members must have had to do this job so hopefully someone knows a simple way to do it :)
I'm aware that I've posted a few questions asking for advice recently so apologies if any of these questions seem a bit simple or unnecessary.
But I thought it'd be more sensible to ask than to spend hours struggling to do it.
Thanks,
Liam
Additional info: 998cc 1989 manual Mini with Hif38 carb and Stage 1 kit including Maniflow exhaust manifold
Edited by zero_wlv, 13 July 2022 - 12:40 PM.
