Dash Button Identification
Posted 02 July 2022 - 02:33 AM
Posted 02 July 2022 - 07:28 AM
On a 1973 I am guessing could be the Wind shield washer system... I think might be wwrong... it is a manual push, so you pump it in and out as fast as you can to wash the windscreen....Make sure there is water in the washer bottle, and preferabley some windscreen cleaner fluid
Posted 02 July 2022 - 08:08 AM
The other switch which confuses many new classic Mini owners is the brake fluid level test light rocker switch.
See link below for details:-
https://www.theminif...ke-test-switch/
The rocker switch has a test function - press the switch and if the system is working correctly the light should illuminate. The switch is a self returning sprung rocker with light.
Edited by mab01uk, 02 July 2022 - 08:12 AM.
Posted 02 July 2022 - 08:52 AM
Should have light, wipers, choke and temp control with washer pump in the centre. Maybe a heated rear window switch but not sure 850's had them in 73. Horn push on the end of the indicator/dip switch.
Edited by imack, 02 July 2022 - 09:05 AM.
Posted 02 July 2022 - 04:07 PM
Thank you all for the replies and assistance.
Posted 02 July 2022 - 04:20 PM
Posted 02 July 2022 - 08:13 PM
The button in the middle is the screen washer pump plunger . The actual pump, as in it should have pipes on the back connecting to a washer bottle and to the washer jets.
Posted 03 July 2022 - 04:03 PM
I always found it quite amusing that in a car that has so few switches they made room for that really weird one that I haven't seen in any other car!
Posted 04 July 2022 - 09:01 AM
Possibly because by the time that switch was introduced every other car had a brake test/warning function built directly into the electrical system by law.
