Just after some general (current) knowledge on the art of sleeving cylinders.
Sleeves - are they readily available ( I have heard of stock shortages)
Are there some better than others - types to look for?
My understanding ( limited ) was that old style pressed in sleeves could distort the block if needed in multiple ( so not able to resleeve all 4 cylinders) ( if true how dated is this info)
My understanding ( see ABOVE) is that newer ones are interference and glued - and now you can say take a 1330 back to standard 1275 ( all 4 cylinders)
What is the useability of a sleeve ( eg I initially resleeved to standard from 1330, can i go to 1293 or 1310 on the same sleeve)
And finally if i have a 1360 offset bored block , still able to be sleeved ?
Any other useful or interesting info , including your experiences both old and new encouraged. Cheers
