Recently replaced the coil (9v ballast with pink wire) with an Intermotor one (GCL1217 - 11070) as I thought the new Lucas coil (DLB102) was the cause of a recent misfire. It wasn’t, it was the electronic module as it was still misfiring, but the new coil was stone cold and refitting the points on a spare baseplate cured the misfire (briefly).
Fitted a brand new set of points and condenser, as the get me home points were pitted thanks to the used condenser being bad (there was a large electrical spark that could be heard during starting) and obviously reset the timing.
It was running great until another 20 miles later and it’s missing (not nearly as bad as it has been) under load pulling away and up hills. I haven’t had a proper look or any tinkering, but did notice once home that the coil was not only hot you could tell it was without touching it. Question is, is it likely to be the condenser that’s fried the coil (don’t want to go fitting another new coil only for the same to happen again) or it’s just the coil that’s faulty?
