Clevis Pin
15 replies to this topic
#1 masslaw
masslaw
  • 109 posts
  • Local Club: Victoria Mini Owners Club
Posted 23 May 2022 - 02:13 AM
I've endured the hell of removing the clutch clevis pin but dropped it, and the new one, and can't find them anywhere (not behind the carpeting). Can I use a nut and bolt until a new pin(s) arrive?
#2 Steam
Steam
  • 756 posts
  • Local Club: Victorian Mini Club
Posted 23 May 2022 - 04:45 AM
As a very temporary measure I might consider a bolt with a hole and the R clip, but not a nut and bolt.
#3 masslaw
masslaw
  • 109 posts
Posted 23 May 2022 - 07:49 AM
I'll try that, thanks
#4 nicklouse
  • 18,577 posts
Posted 23 May 2022 - 08:03 AM
It will have rolled into the cross member. Get it out or it will annoy you for years to come.
#5 Chris1275gt
Chris1275gt
  • 938 posts
Posted 23 May 2022 - 08:22 AM
I put a couple of 5mm magnets in the end of a bit of clear tube over a short bit of old throttle sleeve fished about for the one I dropped and found 2 other old ones, also used it many more times for other dropped items.
#6 Gaz66
Gaz66
  • 894 posts
Posted 23 May 2022 - 02:49 PM
Maybe a tricks and tips sticky would be good for this type of thing.
Theres lots of difficult jobs under the bonnet on a mini!
#7 sonscar
sonscar
  • 2,995 posts
Posted 23 May 2022 - 05:30 PM
Is there really?I was told that there were no difficult jobs,merely interesting and more interesting,Steve..
#8 Gaz66
Gaz66
  • 894 posts
Posted 23 May 2022 - 06:49 PM
Its all about perception, hehe
#9 floormanager
floormanager
  • 681 posts
  • Local Club: Mini Club Sussex
Posted 23 May 2022 - 07:08 PM
Mine's had an oversized bolt and nut for years.  The pedal hole elongated so someone drilled it out to fit a 5/16 bolt.  I've now sourced a new clutch pedal from Nippy cars and will change it over this winter.
#10 Steam
Steam
  • 756 posts
Posted 24 May 2022 - 01:35 AM
On a clutch it maybe just about acceptable but on the brake it is an absolute not.
Many nuts vibrate loose on a mini, the sudden loss of brake or clutch is a seriuos safety issue.
#11 floormanager
floormanager
  • 681 posts
Posted 24 May 2022 - 11:18 AM
Not sure the loss of a clutch is a safety issue.
Interesting thread here
https://mk1-forum.ne...ilit=clevis pin
Edited by floormanager, 24 May 2022 - 12:29 PM.
#12 sonscar
sonscar
  • 2,995 posts
Posted 24 May 2022 - 07:26 PM
When you are sat at a junction revving the engine due to it being reluctant to idle whilst holding in the clutch failure may be a safety issue,Steve..
#13 nicklouse
  • 18,577 posts
Posted 24 May 2022 - 08:18 PM
You mean wearing out the thrust washers.
#14 sonscar
sonscar
  • 2,995 posts
Posted 24 May 2022 - 09:23 PM
When my children were learning to drive they were taught to stay in gear with the clutch in to " be ready to move off"I despaired as they both drove my Mini.They were also encouraged to stop in top gear and "block change" to first when almost stopped,goodbye gearbox.Steve..
#15 Steam
Steam
  • 756 posts
Posted 25 May 2022 - 01:26 AM
By all means use whatever you like on your own vehicle, make sure to tell any potential new owners of the lack of clevis pins.
