Help! Sudden Lose Of Drive In All Gears And Now Has Just A Low Grinding Sound....
Best Answer JamesAlexander , 21 May 2022 - 11:37 AM
Yup it was the drive shaft had popped out of cv joint, broke the retaining washer in the joint, good call Earwax!
Go to the full post
5 replies to this topic
#1 JamesAlexander
JamesAlexander
  • 56 posts
Posted 21 May 2022 - 08:55 AM
Hi folks,
Dusted off the mini for an mot today, drove it up and down the road absolutely fine after having refurbed all the suspension components and regressed pot joints, replaced cv joints, bearings, ball joints, the lot.
I was reversing into my drive on full lock to turn around to drive to the MOT centre and suddenly lost all drive to be replaced with a low grinding noise.  In each gear the pitch gets higher as though the revolutions have been increased but nothing is engaged, any ideas please??
I’m imagining this is an engine out and gearbox off job?!
Many thanks in advance!!!
Edited by JamesAlexander, 21 May 2022 - 09:02 AM.
#2 Earwax
Earwax
  • 611 posts
Posted 21 May 2022 - 09:03 AM
At a guess it could be drop gears......  just on the off chance .......you haven't popped your driveshaft (  (full lock over a bump?)
#3 JamesAlexander
JamesAlexander
  • 56 posts
Posted 21 May 2022 - 09:06 AM
I’ve just attached a video of the noise, both pot joints appear to be still in the diff and drive shafts look to in the right place...
Edited by JamesAlexander, 21 May 2022 - 09:06 AM.
#4 JamesAlexander
JamesAlexander
  • 56 posts
Posted 21 May 2022 - 10:09 AM
I’ve just taken some video from the each side front of the car, the passenger side drive shaft is spinning when the grinding occurs, the drivers side is not, this would appear to indeed be a popped drive shaft or something like that... further investigations required...
#5 JamesAlexander
JamesAlexander
  • 56 posts
Posted 21 May 2022 - 11:37 AM   Best Answer
#6 Earwax
Earwax
  • 611 posts
Posted 21 May 2022 - 09:42 PM
Hi JamesAlexander............ out of most of the possible failures, this one is a `good result'.... i am glad it seems to be a relatively easy and inexpensive fix for you.
