Advice About Buying A Spot Welder
48 replies to this topic
#16 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 May 2022 - 11:18 AM
Thats exactly what you are looking for with a satisfactory weld.
Looks good!
Thanks for sharing
Ben
#17 Viktor
Viktor
  • 653 posts
Posted 22 May 2022 - 12:50 PM
Here are the results from the test Ben has suggested above.
0.8+0.8mm material
Machine set to 0.8 and middle timer setting.
Peel test, smaller hole you see here is from timer set to lowest setting
I had this in the vice on the bench and I could not get it to peel apart, used the vice grips and let them pivot against each other to get it to go.
Thanks Colin, that is really useful and reasuring!
#18 GraemeC
GraemeC
  • 7,435 posts
Posted 25 May 2022 - 10:14 AM
Judging by the instructions the Vevor machine is potentially the same as a Sealey one (seeing as they refer you to a Sealey dealer for a full range of arms and electrodes!)
#19 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 25 May 2022 - 02:28 PM
Had a non timed basic one for many years, one set of arms.  Got it off ebay 2nd hand (they come up on FB Marketplace too).
Great bit of kit but it needs a 16A supply.
When you put sills, an A panel or a front end on it's just so simple and the results look like factory - I've had MOT testers comment on the wing welds 'finally someone who's done it correctly' - 'not like the mini restoration company locally who send their cars to us with lumpy welds everywhere', which I was well chuffed about.
It's also a really usefully tool to have about for general repairs or fabbing stuff out of sheet metal, boxes, mowers getting broken - its endless and will save you £££'s in the long run.
But as has been said previously, spend time experimenting and keep the tips clean and correctly shaped.
#20 colinf1
colinf1
  • 1,009 posts
Posted 25 May 2022 - 08:59 PM
I had been keeping an eye out of FB marketplace and local advert sites for a few weeks, one literally came up for sale a few hours after I bought this one! Hopefully I can get a chance to use it soon, bit of prep work needed before I can try it on the inner wing, even if I only get 50:50 spots to plug welds its a lot less drilling and linishing off!
#21 gaspen
gaspen
  • 932 posts
Posted 16 July 2024 - 06:47 PM
Hello !
I also have a Vevor 230V spot welder but it makes pretty poor welds. For example 1+1 mm metal and default timing : I can break the weld with my hands and the diameter of the weld is approx. 2-3 mm
If I set the both thickness and timing to max. I get some strenght but the diameter is still 3-4 mm only.
As I learnt that it is a Sealey clone so I followed its manual to setup but it did not help.
I am doing something wrong ?
#22 68+86auto
68+86auto
  • 889 posts
  • Local Club: Queensland Mini Car Club
Posted 16 July 2024 - 10:53 PM
Hello !
Have you set the electrode gap properly? Install the bolt that hold the position, the gap should be the thickness of ONE of the panel you are welding together. That means if you are welding two 1mm sheets then put a piece of 1mm in the gap and adjust the electrodes. Also if you happen to be testing the strength by twisting the steel, it will always be easy to break.
It's quite possible that it's faulty - there's a reason vevor is cheap.
Get the Telwin/Sealey one.
#23 gaspen
gaspen
  • 932 posts
Posted 17 July 2024 - 04:35 AM
Hello !
Thanks !
It looks like I misunderstood the manual because I placed double thickness material.
I will make another test
#24 68+86auto
68+86auto
  • 889 posts
Posted 17 July 2024 - 05:07 AM
Hello !
Thanks !
I just read the manual and it's definitely not clear. I'm not sure if I read it elsewhere or if it's just my interpretation but I only use one sheet.
#25 gaspen
gaspen
  • 932 posts
Posted 17 July 2024 - 08:19 AM
Hello !
Thanks !
Meanwhile I talked to a local welder repair workshop. They said that every conact surface must be clean and tight so I will check and clean the machine
1 Volt drop at the electrodes means -1000 amperage
#26 gaspen
gaspen
  • 932 posts
Posted 17 July 2024 - 04:54 PM
Hello !
Well. I dismantled the machine once more. I found two "issues"
1st : the lower arm bracket is screwed to the transformer with 4 screws and "rivnuts" - they are look like rivnuts at least, but they were not squeezed with a tool, just sit in a hole. I could pull them out easily
2nd : one terminal has a bad soldering, not allows to tighten the screw.
I repaired these, put it together but I did not experience any miracle. I get "normal" spotwelds on 1+1 mm material if I set both timing and thickness to maximum.
Peel test is ok, the nuggets diameter is approx 4 mm, but I am not sure if it gives enough strength
Attached File  vevor2.jpg   34.94K   2 downloads
Attached File  vevor1.jpg   42.55K   0 downloads
Attached File  vevor3.jpg   33.67K   0 downloads
Attached File  vevor4.jpg   52.13K   0 downloads
Edited by gaspen, 17 July 2024 - 04:56 PM.
#27 stuart bowes
stuart bowes
  • 2,089 posts
Posted 17 July 2024 - 05:30 PM
is the diameter of the 'spot' not dictated by the profile of the electrode tip?
unfortunately though the flatter (larger diameter) you make the tips, the more current you're going to need to produce a weld, and if you're maxed out already that might not be an option for you
as long as the peel test is leaving a slug behind then surely penetration is sufficient, you'd just need to do enough of them along the join to provide the correct overall strength
where an industrial unit is producing a 8mm spot, just for example, if yours is half that then just do twice as many welds.  The only potential snag there being a 'shunt' effect where if you try and spot weld close to an existing weld the current will go through the previous weld instead of where you want it, and reduces effectiveness, so instead of doing them in a straight line you might want to offset slightly, depending on where you're welding and how close the spots are getting, etc
disclaimer, I've not actually done it myself, I've only read about it in some detail
Edited by stuart bowes, 17 July 2024 - 05:41 PM.
#28 gaspen
gaspen
  • 932 posts
Posted 17 July 2024 - 06:01 PM
This machine has  half-spehere shaped electrodes so I don't know what diameter nuggets I should expect.
I've got an advice for an old specialist that I should sharpen the electrodes and make a small flat where they contact. This way they will heat up quicker and make better welds.
Well... these half-spheres have pretty tiny contact surface, aren't they ?
When I made my 1st Mini I borrowed an older Facom spotwelder. It was more powerful than this new Vevor and it made lovely big spots. Maybe I should not compare the two machines...
Attached File  IMG_20210223_153317.jpg   47.84K   0 downloads
#29 stuart bowes
stuart bowes
  • 2,089 posts
Posted 17 July 2024 - 06:11 PM
yeah that's pretty much what I was thinking, trouble is, you could flatten them and get a larger contact diameter, great, but will your maximum current capability still provide enough heat to penetrate with the larger surface area
you could try, I suppose, but the risk is basically wasting the electrodes, or I suppose having to reprofile them again, depending if the clamping action is adjustable far enough in that way., ?
or just drill / punch a series of holes and plug weld instead, that was my choice but mostly because I don't have a spot welder or a sufficient supply that won't keep tripping (though I have been considering it)
Edited by stuart bowes, 17 July 2024 - 06:13 PM.
#30 gaspen
gaspen
  • 932 posts
Posted 17 July 2024 - 06:33 PM
The conclusion is that vevor has these electrodes because this is its welding capacity.
I've made some test on plug welding with different settings - somewhere they call it "MIG spot welding". Moreover the new MIG welders have timing function.
There is an other gas nozzle for this operation with two spacers on it. What I am afraid of that  will burn the edges of the flanges ...  :mmkay:
Peel test shows #4 plug weld break
Attached File  BIG_0017963605.jpg   31.1K   0 downloads
Attached File  BIG_0017963606.jpg   45.32K   0 downloadsAttached File  BIG_0017963607.jpg   48.88K   0 downloads
Attached File  BIG_0017963610.jpg   35.33K   0 downloads
