Battery Cut Off Switch
18 replies to this topic
#16 KTS
KTS
  • 2,421 posts
Posted 20 May 2022 - 10:19 AM
personally, if a negative earth car, i'd fit to the positive feed off the battery - that way, once disconnected, nothing downstream of the isolator can be live (..assuming the engine is not running !)
Edited by KTS, 20 May 2022 - 10:21 AM.
#17 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 20 May 2022 - 10:48 AM
You can also get isolators with a low-fused bridge wire that allows the radio to retain the settings. But try and start the car and the surge blows the fuse.
#18 KTS
KTS
  • 2,421 posts
Posted 20 May 2022 - 11:05 AM
worth choosing one with a blade type fuse so you can fit a thermal reset fuse and easily get the interior lights working again (Sod's law says it'll be dark when you try and start the car without refitting the isolator key!)
#19 sonscar
sonscar
  • 2,996 posts
Posted 20 May 2022 - 11:48 AM
Nine sixteenths spanner?,Steve..
