Quick Release Battery Terminals
7 replies to this topic
#1 beardylondon
beardylondon
  • 1,524 posts
Posted 17 May 2022 - 03:06 PM
I was thinking of fitting these to my cars, as they do sit for a while in between use and it would save battery drain, and less hassle than having to find a spanner and mess about!
https://www.amazon.c...52799814&sr=8-6
Has anyone ever used these, or could recommend a better brand, the Amazon ones seem a bit crap, going by the reviews
Or Halfrauds?
https://www.halfords...ase-184377.html
Edited by beardylondon, 17 May 2022 - 03:10 PM.
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 17 May 2022 - 03:19 PM
They're really intended for leisure batteries to allow quick and easy removal from caravans etc. and even then they're not brilliant.
I personally wouldn't use them on a car battery that sees high current draw during starting.
A better approach would be a dis-car-nect and leave the low current bypass fuse out:
https://www.amazon.c...y/dp/B0019ULCPW
#3 PoolGuy
PoolGuy
  • 848 posts
Posted 17 May 2022 - 03:23 PM
I use a battery cut off switch, it's as much for safety in the case of a fire as it is for stopping battery drain. https://www.autoelec...152/category/30
#4 beardylondon
beardylondon
  • 1,524 posts
Posted 17 May 2022 - 08:19 PM
Thanks both!
#5 Steam
Steam
  • 756 posts
  • Local Club: Victorian Mini Club
Posted 18 May 2022 - 09:12 AM
The best battery isolators are made for the marine sector.
#6 KidCooper
KidCooper
    Starting My Mini Up
  • 3 posts
Posted 18 May 2022 - 11:33 AM
I bought one of these thinking it would be one you mount to the terminal then attach the cable to it somewhere but it's not.
How did you install it? Also did you put it in the boot near the battery or within reach of the driver?
It'd be nice if I was able to put it under the dash or somewhere, so I could unlock the door get in and reconnect the battery then start up.
 - just thinking out loud really.
#7 PoolGuy
PoolGuy
  • 848 posts
Posted 18 May 2022 - 11:39 AM
Mine's slightly different as it's in my van (which isn't a Mini). It's mounted close to the battery but there's no reason that you couldn't mount it in the boot. It's in the earth cable. This picture probably doesn't help.
Edit: am I doing something wrong that puts the pic sideways?
Edited by PoolGuy, 18 May 2022 - 11:40 AM.
#8 sonscar
sonscar
  • 2,994 posts
Posted 18 May 2022 - 06:36 PM
I like your wiring pool guy,Steve..
