Posted 15 May 2022 - 09:12 AM
I’ve got a Mini 35 which runs a 1275 with a HIF38 carb. I was thinking about upgrading it to a 44 to then have some more options when I buy a stage 2 kit. What are your thoughts on this? Do I need to upgrade the carb/will it help? Also is there anything else that needs to be changed as well (Pipework etc.) or is it a straight swap? Obviously filter/air box would need to change
Any help or knowledge would be greatly appreciated!
Posted 15 May 2022 - 03:31 PM
Phil.
Posted 16 May 2022 - 02:34 PM
You’ll only need the larger carb if you intend on increasing power output. The 38 will flow enough to support around 65bhp before it becomes restrictive.
Phil.
Thanks Phil. So as you say if I was wanting to fit a stage 2 kit it would be ideal to fit the HIF44 as I'd assume I'd be going over 65bhp?
Also, are you aware of any other components which would need to be changed to accommodate the HIF44? It seems like all the same plumbing as the 38 but not sure if I'm missing anything.
Posted 16 May 2022 - 03:15 PM
Phil.Thanks Phil. So as you say if I was wanting to fit a stage 2 kit it would be ideal to fit the HIF44 as I'd assume I'd be going over 65bhp?
Unlikely you will need a 44. But you will not know until you set it up on the rollers.
Mini Technical Sections →
Problems, Questions and Technical →
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
Full Rebuild MethodologyStarted by PeteD , 16 Nov 2024 engine, electrical |
