Hello -
My 1989 998 mini still has the original mechanical fuel pump after 33 years, but only 25k miles.
It looks a simple job to replace - Should I do it before I get stranded or do they last for ages?
Also the car conked out 1 minute after starting this week - apparently with no fuel delivery to the carb. Pump was working OK.
I think the float valve had simply stuck closed although it was moving freely after I got the float chamber lid off to look so its hard to say.
Anyhow the car is now working but is it common for the valve to stick shut?
I probably need to add a filter between pump and float bowl as the car often stands for weeks.
