Wheel Bearing Noise Or Something Else?
Best Answer MacGyver , 14 May 2022 - 10:10 AM
Sounds like the noise my speedo cable did a few years ago. Try that. It's literally plug and play...
Ben Go to the full post
17 replies to this topic
#16 maystro
maystro
  • 298 posts
Posted 16 May 2022 - 07:01 AM
Spider, on 16 May 2022 - 04:50 AM, said:
maystro, on 15 May 2022 - 7:55 PM, said:
I was thinking of just undoing the cable on the gearbox end to test. Is this the best way to test?
That's what I's suggest as that'll stop the cable spinning.
There a few ways to get to the gearbox end of it, these days, I jack up the passenger's side quite high (so the engine oil doesn't leak out), pop the top ball joint, than take out the Pot Joint, reach up from under, it's 'right there'.
Thanks Spider,
That pot removal trick worked a treat and as you know I am getting pretty good at splitting those ball joints which has seemed a weekly occurrence since slowly replacing nearly my whole front end looking for this elusive squeaking/scraping noise.
Anyway great news, the noise has gone. Not one chirp, squeak or scrape.
This was doing my head in.
So I have ordered a new 36inch speedo cable, hopefully that is the right length. I think it is a bit longer than my original but that is what I was recommended by the guys at Minisport in Adelaide?
So a big Thankyou to @MacGyver and @Spider.
Edited by maystro, 16 May 2022 - 07:06 AM.
#17 Spider
  • 14,838 posts
Posted 16 May 2022 - 08:51 AM
Result !
#18 MacGyver
MacGyver
  • 1,027 posts
Posted 16 May 2022 - 06:20 PM
👍 Glad it's put your mind (ears) to rest! 😋
Ben
