Voltage Regulator/generator Question(S)
Posted 04 May 2022 - 04:53 AM
Posted 04 May 2022 - 05:09 AM
Posted 04 May 2022 - 07:59 AM
,,,,,, The question is, am I able to read regulated generator output voltage at the battery terminals?
Yes.
As Timmy has said, it doesn't sound like it's charging. With the engine at 2000 RPM or higher, you should see 13.5 Volts or more.
Posted 04 May 2022 - 09:26 AM
As Spider alluded to, you need to run the engine at a bit of a lick to get a meaningful reading...
Some info on the RB340 here:-
https://www.lrsoc.co...orkshop-manual/
Section B5
Posted 04 May 2022 - 05:48 PM
If the voltage regulator is a genuine Lucas RB340 it has adjustments on the coils. There should be adjustable cams at the back of the coils, by the back I refer to the front as being the terminal side.
The charging voltage output is in the region of 12.7 to 13.4 volts dependant on load conditions. Setting up and adjusting these regulators is a long drawn out task and too long to explain here. There will be I have no doubt explanations on how to do this on the internet, Google Lucas RB340 voltage regulator set up.
There are some very poor examples of "new" voltage regulators out there, so do not be surprised if the replacement unit is faulty.
Measuring the current output of the unit, Max 22 amp, is an indication of the system health, put on all the vehicle electrical loads and measure the charge current.
Posted 04 May 2022 - 10:43 PM
Section B5
Thanks for the information.
Posted 05 May 2022 - 07:21 PM
Section B5
Just printed this info and was gratified to see how well the Lucas workshop instructions are written and more easily understood than the shortened version in both of my manuals. Thanks again.
