Leaking Brake Fluid
17 replies to this topic
#1 Elwyn
Elwyn
  • 365 posts
Posted 01 May 2022 - 07:21 PM
Hello
1993 L reg SPI Cooper, Manual, RHD
Front brakes
I've replaced the hoses to the callipers with Goodridge braided hoses
I have a leak at the right hand side
At the banjo bolt / 2-way union
I replaced the 2 copper washers, securing nut and shake-proof washer at the banjo bolt
The banjo bolt is original
The copper brake lines up to and after the 2-way banjo union on the subframe are original
The two way banjo union is original
There is no leak from the copper brake lines up to and after the 2-way banjo union on the subframe
The leak is coming from between the head of the banjo bolt, the upper washer and the 2-way union
In blue on the attached diagram (but when all tightened up)
I've taken it all apart, cleaned all the parts, reassembled everything and it leaks in exactly the same place
Any thoughts, suggestion etc?
Thanks in advance
Elwyn
Attached File  Mini Forum 2 way banjo brake leak.GIF   13.97K   0 downloads
#2 Quinlan minor
Quinlan minor
  • 1,075 posts
  • Local Club: LSMOC
Posted 01 May 2022 - 07:32 PM
Have you annealed the copper washers?
#3 Elwyn
Elwyn
  • 365 posts
Posted 01 May 2022 - 07:35 PM
No
Didn't realise I had to do that with a new washer / washers
Replace the washers, heat them up with a blow torch and allow them to cool naturally?
#4 Quinlan minor
Quinlan minor
  • 1,075 posts
  • Local Club: LSMOC
Posted 01 May 2022 - 08:16 PM
Cherry red, then I tend to quench mine in oil, but natural cooling works, too.
#5 Elwyn
Elwyn
  • 365 posts
Posted 01 May 2022 - 08:49 PM
I'll give a it a go
#6 tmsmini
tmsmini
  • 720 posts
  • Local Club: MOASF
Posted 02 May 2022 - 01:43 AM
I seem to remember that one of the hoses end fittings was either slightly longer or slightly shorter when fitted to the two way splitter.
I cannot find any documentation anywhere though
#7 IronmanG
IronmanG
  • 1,187 posts
  • Local Club: Box hill. Lsmoc member
Posted 02 May 2022 - 06:18 AM
The minispares ones? Yes they are handed. https://www.minispar...px|Back to shop
#8 absx2
absx2
  • 852 posts
Posted 02 May 2022 - 08:20 AM
Yep, the hoses are handed .
A deeper hole for the union side.
#9 tmsmini
tmsmini
  • 720 posts
  • Local Club: MOASF
Posted 02 May 2022 - 04:15 PM
I could not find this when looking:
Pair of front only braided steel hoses. Please be aware these are sided, the deeper threaded hose fits the right hand side, the shallower hose fits the passenger side.
 The MS picture says Goodridge, but the current Goodridge version are covered with heat shrink which is a nice feature.
Edited by tmsmini, 02 May 2022 - 04:15 PM.
#10 nicklouse
  • 18,178 posts
Posted 02 May 2022 - 05:30 PM
It might be the way you have written this or it might be your problem. There is no shake proof washer on the banjo connection. Just a copper washer each side and they are not the same size.
#11 Elwyn
Elwyn
  • 365 posts
Posted 02 May 2022 - 06:52 PM
The shake proof washer (23 below) sits below the nut (21 below) that secures the brake hoses (16 below, from calliper) to the subframe, as they're secured. screwed into the nut (21) from underneath
The two differently sized copper washers (19 & 20) are part of the banjo bolt (18) to 2-way union (17) connection
Attached File  Mini Forum 2 way banjo brake leak.GIF   13.97K   1 downloads
The braided hoses were from MS, but they're a Goodridge product
The MS website states the following
Please be aware the fronts are sided, the deeper threaded hose fits the right hand side, the shallower hose fits the UK passenger side.
But the two front hoses in the Goodridge pack were / are identical
The two thread depths below were / are the same
Attached File  Mini Forum Goodridge flexi brake braided hoses.GIF   45.41K   1 downloads
#12 Elwyn
Elwyn
  • 365 posts
Posted 02 May 2022 - 06:56 PM
Deeper thread?
Deeper hole?
I'm not sure what to look for
if I've got the hoses the wrong way round, that's an easy fix
I'd be delighted with that as an outcome
#13 sonscar
sonscar
  • 2,842 posts
Posted 02 May 2022 - 07:00 PM
Is it talking about the internal thread?It is a while since I changed these and mine did not have the brake switch takeoff but a bolt?The picture is incorrectly scaled I think as it would appear that one copper washer seals on top of the nut?Might be mistaken,Steve..
#14 tmsmini
tmsmini
  • 720 posts
  • Local Club: MOASF
Posted 02 May 2022 - 08:11 PM
It is the internal thread depth, I believe.
#15 IronmanG
IronmanG
  • 1,187 posts
Posted 02 May 2022 - 08:29 PM
The internal hole is deeper on drivers side and I think has the sleeve on it. It allows the banjo bolt to go further into the hose fitting. Dont ask how I know....
