Ball Joint Review O E M Type From Japan
31 replies to this topic
#16 MatthewsDad
MatthewsDad
  • 812 posts
Posted 16 August 2024 - 05:52 AM
What a pity. All we're asking for are components made to the same standard as half a century ago.
#17 Steam
Steam
  • 756 posts
  • Local Club: Victorian Mini Club
Posted 16 August 2024 - 09:31 AM
Thanks for posting the update Chris, very timely as I am in need of a set and was considering these.
I now wont have to be dissapointed.
Excellent review.
#18 gaspen
gaspen
  • 942 posts
Posted 17 August 2024 - 08:51 AM
I believe you can get these now from Guess-works (UK) without having to get them sent from Japan. (Advertised as the same thing)
http://www.guess-wor...play.htm?id=611
These are a different joint to those I reviewed here.
Those offered by Guess Works are the Sealed Maintenance Free Joints (I'll be doing a review on these).
Those reviewed here are of the same design as the Original Joints and in my view, of similar quality.
I am confused here. The text on GW's link says : These balljoints are imported from Japan...
Are there two manufacturers in Japan ? Or I missed something ?
#19 timmy850
timmy850
  • 3,328 posts
  • Local Club: MITG
Posted 17 August 2024 - 10:50 PM
With the “sealed maintenance free no shim” ball joints:
Guessworks ones are a different manufacturer to the Classic Mini Japan items
Classic mini Japan = Minispares = Mini Delta
#20 gaspen
gaspen
  • 942 posts
Posted 18 August 2024 - 05:03 AM
I see, that's make sense, thanks
I've installed ball joints to my 1st Mini from ClassicMiniJapan but it drive it very little.
GW's NSR ball joints are better ?
I have a standard set which I bought from MiniSpares, I plan to install it to my 2nd Mini
Should I scrap them instead ?
#21 Spider
  • 14,841 posts
Posted 18 August 2024 - 05:51 AM
This thread is actually about standard type ball joints, not the maintenance free types.
All the maintenance free joints currently available do not have enough swivel angle and are potentially dangerous. I don't recommend any of them.
If you have Ball Joints from Mini Spares, fit those, they are about as good as any other stock replacement ball joint currently available and while they may wear, they won't break.
#22 Spider
  • 14,841 posts
Posted 09 September 2024 - 09:33 AM
I had the opportunity this afternoon to do some hardness testing of some of the Pins. We tested on the smaller ball on the pins, as with the gear we had, that was the easiest to do, though we did double check on some on the bigger ball.
BMC Joint from the 70's     47 Rc on big and small ball
Unipart Joint*                      45 Rc   * These were their 'new' joints after the original stock had sold out. They have a turned finish, not ground like the originals.
After-market                       47 Rc on the small ball
OEM Jap Joints                  23 Rc on the big and small balls. We also checked on that very worn joint and found that too was only 23 Rc, indicating that they were likely 1045 mild steel with no heat treatment.
I'll also point out here that while some might appear 'good' these figures alone are not really enough to go off, though, clearly the current OEM Japanese joints are utter rubbish. When time permits, I'll grind a few of these joints to do further tests to get a depth of hardness as some only have a very thin case on them.
#23 Designer
Designer
  • 579 posts
  • Local Club: LSMOC
Posted 09 September 2024 - 10:49 AM
Thank you Spider for the excellent research that you do on all of our behalf.
Large applause and three loud cheers.
Paddy
#24 Fred&Rex
Fred&Rex
  • 125 posts
Posted 03 November 2024 - 12:21 AM
Hi everyone
Maintenance free ball joints and lowered minis are there any complications, keep hearing about swivel angles etc etc.
Thanks again
Daz
#25 Spider
  • 14,841 posts
Posted 03 November 2024 - 01:43 AM
Hi everyone
Thanks again
Daz
Yes, there are issues, lowered, raised or standard height.
The Maintenance Free ones only have a swivel angle of about 400 while I've not actually measure it yet, but it's clear to see they fall well short.
The original Mini Ball Joints have a 550 swivel angle and they need every degree of that and more if dialing in any amount of negative camber.
Put another way, they are not fit for purpose.
#26 Fred&Rex
Fred&Rex
  • 125 posts
Posted 03 November 2024 - 08:53 AM
Thanks Spider for the info l, I have a set fitted and from hearing about this thought I would ask. Although I’ve not driven much yet I’m wondering what potentially could go wrong
The swivel snaps? Geometry issues? Steering problems?
If going back to original shimming which ones are we choosing as most are junk in reality.
NOS or any particular brands
Thanks again
#27 Spider
  • 14,841 posts
Posted 03 November 2024 - 09:37 AM
Thanks again
Particularly if the suspension is raised or lower it will increase the probability of a swivel pin and / or the cup of the joint breaking, though, this will still likely happen at standard height too, but might take longer. As the suspension moves to the point of where the pin contacts the cup, it will have odd effects to suspension travel and could well cause the steering to get suddenly stiff or even lock.
I have tested on the bench just how much angle these joints need an while they do have a high angle of movement (at 550) then definitely need every single degree of that. Even with standard joints, if any additional negative camber is dialed in, on full droop, the lower pin will bind on the cup, especially if any steering angle is also dialed in. By 'any additional negative camber' I mean that the stock camber is +2 to 30 , even moving this to +1 is well enough to cause issues.
The factory never offered adjustable arms, however, through Special Tuning they did off longer lower arms (actually, these were the same forging, just machined differently), and they gave an installation instruction that included adding a 1/8" (3 mm) packer under the rebound stop pad of the upper arms to reduce the droop and reduce the risk of this issue.
As for what I'd suggest to use, if you can find genuine NOS joints, they were extremely high quality and very good, my next choice though nowhere near as good but about the best you'll get off the shelf would be those from Mini Spares.
#28 Fred&Rex
Fred&Rex
  • 125 posts
Posted 03 November 2024 - 09:56 AM
Thanks Spider, wow very detailed explanation which I very much appreciate, will you be testing the swivel angle of the maintenance free ball joints out of interest.
From memory QH ball joint kits were good and I fitted them in the 90s without any problems.
Regards
Daz
#29 Steam
Steam
  • 756 posts
Posted 04 November 2024 - 03:22 AM
Sometimes the OCD eff3ct of never throwing anything out actually pays off. I have a drawer full of preloved ball joints which are probobly still usable and sounds like better quality than new.
Now where do I find new, quality dust covers. ;-)
#30 GraemeC
GraemeC
  • 7,438 posts
Posted 06 November 2024 - 05:19 PM
Catmint did develop some new dust covers I think, but can't get to their website at the moment
MiniSpares also do them, but not sure how long they last.
