'79 Mini 1000, not run for 23y. I took out the fuel tank, cleaned it inside with a hose a few times, let it dry, put it all back in the car, put some fuel in (2 gallons) and nothing comes out of the pipe out the bottom! Took the petrol back out, removed the tank again, and I cannot blow air into the tank through the exit pipe. Something appears to be blocking it.
I shoved a bit of wire down it and it just stops. Then I took out the fuel gauge sender for a closer look including with an endoscope. It seems the exit pipe is connected to an internal tube which goes to some kind of pickup (presumably at the lowest point of the tank).
The tank itself appears to be made in two halves which are crimped together in the middle and then presumably brazed for a fuel-tight seal? There isn't any way of disassembling it that I can see to get at that internal pipe.
Any tips or clues as to what might be going on here or suggestions for how to fix it before I fill the tank with water and then cut an access hole in the side of it (which I will TIG shut again afterwards)?
