Trolley Jack Max Lifting Height For A Classic Mini?
20 replies to this topic
#1 Kawh1
Kawh1
  • 84 posts
Posted 18 April 2022 - 11:12 PM
Hello,
Just looking around to get a trolley jack for the man cave and I was wondering what max lifting height is recommended for a Classic Mini?
#2 nicklouse
  • 18,574 posts
Posted 18 April 2022 - 11:36 PM
No such thing.
#3 Kawh1
Kawh1
  • 84 posts
Posted 19 April 2022 - 12:31 AM
Thanks so much for that..
#4 Spider
  • 14,836 posts
Posted 19 April 2022 - 12:39 AM
Get one that will fit under your jacking points when it's lowered, that might be the greatest challenge as far as how high it will go, not being smart but as high as you can get. Off hand, mine goes to about 600 mm.
#5 Kawh1
Kawh1
  • 84 posts
Posted 19 April 2022 - 01:15 AM
Great, thanks for the info, I'll check it out - cheers
#6 Steam
Steam
  • 756 posts
  • Local Club: Victorian Mini Club
Posted 19 April 2022 - 07:21 AM
Also keep in mind that with a flat tyre the car is even lower.
#7 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 19 April 2022 - 08:16 AM
We had a mid range size trolley Jack in the workshop that with a chunk of wood would enable me to fit the car on the spit
The ones you get inHalfords etc are fine but I have a Clarke low entry one at home which for day to day jobs is fine. Any thing higher would need a bigger one.
#8 JVA10L
JVA10L
  • 181 posts
Posted 19 April 2022 - 09:29 AM
I found this in an old BMC manual so I made one myself. Makes lifting the front with a trolley jack really easy. Attached File  JackBlock.JPG   65.6K   45 downloads
#9 Ethel
  • 25,919 posts
Posted 19 April 2022 - 10:59 AM
How high is the ceiling?
Seriously, how much  space you have to work in is as big a factor if you're to get the thing under the car & pump it up. Ask yourself why you'll be jacking it up, often you'll just need enough height to get an axle stand in. If you need to get it higher to get underneath, you can use timber blocks & lift it in stages. It gets more dangerous when you're jacking things at extreme angles more than how high you're lifting them
#10 Bunji81
Bunji81
  • Validating
  • 26 posts
Posted 19 April 2022 - 11:05 AM
I found this in an old BMC manual so I made one myself. Makes lifting the front with a trolley jack really easy. attachicon.gif JackBlock.JPG
found this to be quite interesting…. Has anyone tried it on any later models?
#11 sonscar
sonscar
  • 2,994 posts
Posted 19 April 2022 - 11:09 AM
I have a similar block for my 1989 car,though not to such exacting measurements.Cannot see why everyone would not have one,Steve..
#12 Maccmike8
Maccmike8
  • 1,101 posts
Posted 19 April 2022 - 04:31 PM
Ive got a low profile jack which goes really high.
Its not this one but not dissimilar - https://www.halfords...ZxoCAwMQAvD_BwE
#13 stuart bowes
stuart bowes
  • 2,100 posts
Posted 19 April 2022 - 04:40 PM
when they put it up on the lift in the garage it goes about 6 foot up in the air..
as mentioned angle is more of a danger than height.  If you're going up on 4 stands, do the back end a bit, level up the front end, front a bit more, level up the back, etc
until you fit underneath, which for me (lockdown + pizza / indian takeaways) is much higher than I'd care to admit
I've got this one https://www.machinem...ft-low-profile/ which to be honest is a bit of a pain because the arm is quite long but you can half it if you need.  goes more than high enough.  I got a 2tonne one because I also do a lot of work on my Volvo
Edited by stuart bowes, 19 April 2022 - 04:42 PM.
#14 Ol timer
Ol timer
  • 329 posts
Posted 19 April 2022 - 10:24 PM
too right. I carry one in the car and had a flat at the front. couldn't get the jack under.. had to drive up a kerb then managed
#15 Spider
  • 14,836 posts
Posted 20 April 2022 - 12:38 AM
I feel for a garage jack to do general maintenance to rebuilds, a trolley jack is the a good one to use.
For a Mini, I found the best jack to carry in it for changing flats and even minor road side repairs is the sill jack they came with or a scissor jack. Both store compact, weigh little, go very low, yet can raise up high. They are not terribly stable so not really recommended for doing any work per se, but for their intended use I think are fine.
