Mini Van Washer Fluid Bottle Location?
8 replies to this topic
#1 Bearddude
Bearddude
  • 16 posts
Posted 18 April 2022 - 02:35 PM
Hi, can anyone advise the location of the washer fluid bottle in a Morris Mini Van? I know it’s in the boot for cars…..I can only see a tube from the washer jets running back into the top of the bulkhead. I know my van is heavily customised but knowing where it should normally be might help 🥴 Cheers
#2 nicklouse
  • 18,479 posts
Posted 18 April 2022 - 02:57 PM
Bulkhead or inner wing. Like the cars of the same year.
cars only had it in the boot for the last few years.
#3 Bearddude
Bearddude
  • 16 posts
Posted 18 April 2022 - 06:24 PM
Thanks - I’ll get the wheel off and take a look.
#4 nicklouse
  • 18,479 posts
Posted 18 April 2022 - 06:58 PM
In the engine bay.
#5 KTS
KTS
  • 2,411 posts
Posted 18 April 2022 - 08:13 PM
either here...
..or on the inner wing above the clutch cover..
#6 IronmanG
IronmanG
  • 1,223 posts
  • Local Club: Box hill. Lsmoc member
Posted 19 April 2022 - 06:54 AM
Lovely trick bits in there Pat. What lambda you running. My connector is wedged right in between the subframe and toeboard.
#7 KTS
KTS
  • 2,411 posts
Posted 19 April 2022 - 09:31 AM
AFR gauge is an AEM 30-4110
#8 Bearddude
Bearddude
  • 16 posts
Posted 04 July 2022 - 07:21 PM
Well, I eventually found the location of the windscreen washer bottle in my van. It was tucked away in the driver side wheel arch……
Edited by Bearddude, 04 July 2022 - 07:21 PM.
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,316 posts
  • Local Club: Amoc
Posted 06 July 2022 - 07:28 AM
Good luck filling that up...... unless it has a standard rust hole in the scuttle...
