Radius Arm Bush Measurements For Reference
4 replies to this topic
#1 hungdynasty
hungdynasty
  • 173 posts
Posted 10 April 2022 - 08:04 AM
I bought the radius arm kit from Minispares and took some measurements for your reference
Bush Outside 23.925mm
Inside 20.350mm
Bearing Outside 27.000mm
Shaft 20.625mm
Therefore we need an adjustable reamer of size 20-21mm.
#2 nicklouse
  • 18,577 posts
Posted 10 April 2022 - 10:54 AM
Inside 20.350mm
Shaft 20.625mm
Not really as you are not just reaming to bush to size you are also reaming it to be parallel to the bearing at the other end.
#3 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 10 April 2022 - 12:31 PM
This should give you an idea of what is involved in refurbishing the radius arm:
https://www.theminif...th-radius-arms/
#4 hungdynasty
hungdynasty
  • 173 posts
Posted 10 April 2022 - 01:35 PM
Inside 20.350mm
Shaft 20.625mm
Yes, I DIY a set using a steel bar and a bearing race to hold the reamer parallel while reaming.
#5 Myminiproject
Myminiproject
  • Just Joined
  • 22 posts
Posted 21 December 2023 - 08:04 PM
Hi all,
Just reamed my radius arm bronze bushes by keep trying fitting in the shaft and keep reaming. Measuring 20.7mm on the bush inner and 20.6mm on the shaft. Is this 0.1mm about the right gap - there is a little play on the shaft.
Thank you for any help.
MMP
Edited by Myminiproject, 21 December 2023 - 08:18 PM.
