Hi everybody, I am new to this forum and would like some general advice. I have, perhaps rashly, offered to recommission by daughter's 1979 Mini City and return it to the road.. It's a peach of a car, she bought it 20 years ago from it's first lady owner, ran it for a year and then retired it to my barn, where it has sat ever since. Unsurprisingly, all the wheel cylinders were seized and the flexible hoses collapsed. I have replace all of these (six wheel cylinders and four flexibles). The car has the dual circuit front/rear split braking system and the existing master cylinder is the type with a switch which I believe monitors the brake pressure equaliser, which is mounted on the bulkhead. It is NOT the master cylinder with a switch in the cap. As I am intending to change from Glycol based dot 4 brake fluid to Dot 5 Silicon fluid I would like to replace to master cylinder as well as the rest of the braking system. The current master cylinder is currently no longer available ( though a repair kit is available). I would prefer to fit an all new cylinder, so my question is: can I fit the later type cylinder? - I think the number is GMC227. I understand this cylinder has metric connecter threads, but otherwise it looks identical, so if I put the correct metric connectors on the brake pipes will it be a straight swop, using the existing mounting points. If I then change the existing electrical connection to two spade terminals that will connect with the cap, will everything work as intended?
I have also seen the terms Yellow Tag and Black Tag in relation to these master cylinders, can anyone tell me what the difference is?
Thanks for your patience in reading this.
