Crazy's 1980 Hl - The Journey Continues.....
#136
Posted 26 June 2022 - 02:53 PM
#137
Posted 26 June 2022 - 04:22 PM
Function over form if you like so if the setup requires a longer suspension travel, they can be moved up with cut arches to suit.
My mind tells me the hinged brackets are so that they can be fastened where required without the brackets being at the wrong angle.
I could be wrong though.
Ben
Edited by Ben_O, 26 June 2022 - 04:23 PM.
#138
Posted 30 June 2022 - 10:04 PM
#139
Posted 30 June 2022 - 11:28 PM
Any further progress…
ughhhh i was wondering but not that much patience is a virtue
#140
Posted 01 July 2022 - 08:12 AM
I've been working at this but had nothing worthy of an update.
Just hours and hours of primer flatting.
It's almost done now so I will soon be moving onto the painting process.
Ben
#141
Posted 01 July 2022 - 02:23 PM
Ok, I've given up in the arches for now.
I can't decide the exact position and with no wheels on the car, I'm not going to be able to get them just right so i have decided to wait until the car is reassembled.
So after days of sanding the last of the body prep is complete.
Now for the floor bungs.
Unfortunately I didn't order enough for some reason but I'll fit what I have.
First they push into the holes
Then I warm them with the hot air gun.
Keep going until the red seal starts to shine and melt. My gun on full power takes about 10 seconds
Then push firmly and evenly down with something flat and heavy.
I use a dolly
The underside looks like this
Then I bend the tabs back
And that's it.
Next job, sealing up.
Ben
#142
Posted 01 July 2022 - 04:50 PM
#143
Posted 01 July 2022 - 05:05 PM
Getting close to painting, looking forward to that.
Daz
#144
Posted 01 July 2022 - 06:23 PM
#145
Posted 01 July 2022 - 06:57 PM
What is the purpose of floor bungs what do they do?
I think its a drain if the interior of the car got flooded you can pop them rather than resorting to drilling a hole..
#146
Posted 01 July 2022 - 06:59 PM
I use a dolly
And that's it.
Ben
They look superb
#147
When the shells are produced, they are coated in the factory using a process called rotodipping.
These holes are punched out during manufacture so that when the shells have been dipped the excess coating can drain out.
The steel bungs are then fitted to seal up the holes prior to the antidrum being applied over the top.
Some people replace with rubber bungs, others plate the holes up entirely. I like the originality of these steel bungs personally.
It's a common misconception that the bungs are there to be removed to drain out water if necessary..
Edited by Ben_O, 01 July 2022 - 07:02 PM.
#148
Ah thanks Colin
#149
Posted 01 July 2022 - 07:01 PM
Thats good to know, I'm thinking of welding mine up!
#150
Posted 01 July 2022 - 07:23 PM
Thanks for clearing that up Ben always handy to learn something new.
