Crazy's 1980 Hl - The Journey Continues.....
281 replies to this topic
#31 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 May 2022 - 02:15 PM
Pary of my panel order was delayed meaning I didn't have the floor pans to continue on from where I left off so I decided to sort the boot floor and replace the valance.
First job, remove the old valance
It's all pretty good under there with just some surface rust for the most part.
One closing panel is fine so will not need replacing
I'll just clean that one up.
The other side will need replacing as there is corrosion under the edge of it
So off with the old
And then after a clean up, I had to chop out sections of the back panel and boot floor to replace.
And then on with the new closer
Next up, I prepped the new valance
Clamped it on
And spot welded it into place
Ben
#32 Crazy
Crazy
  • 274 posts
Posted 11 May 2022 - 02:27 PM
Super work as usual Ben,
#33 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 May 2022 - 02:28 PM
After a few days, the other parcel arrived containing thr floor pans so I cracked on with that.
Here is the new left front pan marked up for rough cut
And then cut and positioned in place
Next I marked exactly where it needed cutting to join the existing floor and then trimmed and clamped into place
And then tacked
I left a fairly big gap in the join as I intend to grind both sides flush after welding so need perfect penetration the whole way.
And here it is fully butt welded
And we have perfect even penetration the other side too
I gave it a grind up
And then drilled and plug welded the front edge to the toe board
Then I reclaimed the slinging bracket and welded that back
Then made and fitted a new carpet retaining plate
Job done.
Next up is the replacement step and outer sill.
Ben
#34 Fred&Rex
Fred&Rex
  • 127 posts
Posted 11 May 2022 - 05:43 PM
Wow
Amazing work going on, special set of skills, looking great, hoping mine might receive the magic soon.
#35 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 May 2022 - 11:41 AM
Next step is the step.
First thing to do is cut out this section of quarter panel to give me access.
It needs replacing anyway.
Then drill and cut the step off
Then replace the jacking point
Next up, I trimmed the step panel down to just oversize and laid it in place to mark my cut lines
Then cut and welded
Then spot welded the rest
After that, I made up a new section of quarter panel to close off the previously opened up part
And welded it in
Next job will be the outer sill and lower flitch repair.
Ben
#36 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 May 2022 - 02:09 PM
Next I prepped and clamped on the outer sill
And then spot welded the top to the step and quarter panel
And then finished by plug welding the bottom edge to the inner sill and jacking point
That just leaves the flitch repairs on this side now
#37 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 May 2022 - 03:29 PM
All these small repairs start off with a card template
Then transferred to steel
Before being welded and dressed back
#38 JXC Mini GT
JXC Mini GT
  • 852 posts
Posted 12 May 2022 - 03:59 PM
Great work Ben, another masterclass of how to repair your Mini.
#39 Fred&Rex
Fred&Rex
  • 127 posts
Posted 12 May 2022 - 04:42 PM
Loving these repairs…
#40 Crazy
Crazy
  • 274 posts
Posted 12 May 2022 - 05:03 PM
holy smokes quite an update today Ben, such a magician with all these little bits, great seeing the step by step photo's
#41 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 12 May 2022 - 08:02 PM
Great work as always Ben, I always enjoy your posts very inspiring.
#42 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 May 2022 - 03:30 PM
I made a start on the other side today
I cut the outer sill off
And then made a decision on how much of the floor pan I will replace.
Here it is marked out for cutting
And then cut
I then removed the lower section of flitch as it's a bit grotty
Then had a good clean up
Before roughly trimming the new section of floor
Here it is fully trimmed and clamped in place
Tacked
And fully welded
#43 colinf1
colinf1
  • 1,026 posts
Posted 13 May 2022 - 03:40 PM
Looking good Ben! Was there any numbers stamped on the lower section of the flitch to suggest it was the original inner wing?
#44 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 May 2022 - 03:55 PM
Cheers.
There were no numbers stamped but also no evidence that its not the original inner wing.
It was all factory apart from the ugly mot patch
Ben
#45 Fred&Rex
Fred&Rex
  • 127 posts
Posted 13 May 2022 - 05:02 PM
Superb work as usual, credit to you Ben I couldn’t do what you’re doing..
Daz
Nudge nudge, send me a cost for mine please!
