Which Baulk Rings
Posted 30 March 2022 - 10:59 PM
I was wondering which were the best quality baulk rings available today?
Does anyone have experience of the rings available from Classic Minis Japan?
Posted 31 March 2022 - 08:31 AM
Posted 31 March 2022 - 09:08 AM
Posted 31 March 2022 - 11:42 AM
No issues with the sets I've bought from Guessworks. Double check your clearance mind, even though John's are good, they can't make up for a worn syncro cone (as I found to my cost).
Edited by Icey, 31 March 2022 - 11:47 AM.
Posted 31 March 2022 - 12:32 PM
It would be funny if they all came from the same supplier.
Posted 03 April 2022 - 09:32 AM
Thanks Icey, Is there a video describing how to check the clearances?
Posted 03 April 2022 - 07:35 PM
They are likely very thin on the ground now but I always had good success with the genuine Rover Baulk Rings. I know some people gave them a bad rap however I've only had one that I found on inspection to be slightly out of round. When everything else that needs to be checked is right, I can select 1st gear at 60 mph - though I've never let the clutch out ! It's just a test !! I've fitted loads of them.
Here's where to check the clearance, measurement B;-
Posted 04 April 2022 - 08:16 AM
Petrol covers this in their rebuild thread, for testing on the bench...
Baulk ring clearnace
For the box I've just built, I checked them all on the bench using a machine vice to hold (not clamp) the ring and gear square, and all were around the 'new' clearance (within 0.01-2mm). When I compare it to the old box where I didn't measure I can see the same measurement is much smaller (so the ring sits higher up the cone).
Edited by Icey, 04 April 2022 - 08:16 AM.
Posted 25 November 2023 - 09:03 AM
Hello
When you measure the gap of baulk ring do you just drop it on its place or do you apply some pressure?
Posted 25 November 2023 - 10:32 AM
The question is where do guessworks get them from.
Anyone who is having their own rings made would be sure to shout about it. I haven't seen any such claims.
Posted 25 November 2023 - 12:55 PM
Don't know if it's still the case but John Guess used to check his baulk rings on a lathe and correct any distortion caused by the welding of the spurs.
Posted 25 November 2023 - 01:55 PM
Surely that’s standard when building a box?
Posted 25 November 2023 - 03:05 PM
Shooter
Posted 26 November 2023 - 02:19 AM
As mentioned above, the genuine Rover Baulk Rings I found great, easily as good, if not better than the early 'w' types. I also had very good success with the earlier Mini Spares rings. More lately, on a suggestion from Graeme C, I've tried a few sets of MED Rings, which are a little unique in design, with changes to make them last longer and had great success with them. Very fairly priced and a top class product.
