Best Headlights?
27 replies to this topic
#16 Cooperman
  • 23,276 posts
Posted 04 April 2022 - 02:43 PM
I run CIBIE H180 headlights with Osram Nightbreaker lamps. It’s not just wattage that counts, the beam pattern with the H180s are superior to anything else I’ve tried. Just very difficult to find the CIBIEs now though.
+1
#17 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 05 April 2022 - 05:25 AM
Just another combo to confuse you :-)
Cibie 180s with The Classic Car LEDs in warm 3000K white. https://www.classicc...t=8239029715039
The best I've found so far..
#18 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 07 April 2022 - 02:49 PM
Have you got these ones? And any pictures of them at night? My idles drops to near enough cutting out with my current headlights so would like some LED to hopefully not crop the power too much.
#19 Chapperscfc84
Chapperscfc84
    Just On Tickover
  • 9 posts
Posted 10 April 2022 - 09:27 PM
Im about a month off finishing mine and will be fitting Dapper lighting OE7s if they’re as good as they say are they should be incredible. They look very original as well and look they’ve been well made.
I can’t wait to get them in and see how good they are. Il post when I do
#20 unburntfuelinthemorning
  • 1,982 posts
Posted 23 April 2022 - 11:07 AM
Another vote here for the Cibies.  Good quality units.  Not sure what to do if i need to replace them.
Which lamps are the proper domed shape?  I'm not keen on the flat lenses.  That dunt luk roight!
#21 PoolGuy
PoolGuy
  • 848 posts
Posted 23 April 2022 - 07:01 PM
I'm interested to hear how you get on with these, please keep us updated.
#22 ac427
ac427
  • 674 posts
Posted 26 April 2022 - 01:14 PM
Did you have to purchase them directly from Dapper themselves?
#23 Compdoc
Compdoc
  • 609 posts
Posted 27 April 2022 - 04:42 PM
Classic Mini DIY have a You Tube video on these.
Edited by Compdoc, 27 April 2022 - 04:45 PM.
#24 SolarB
SolarB
  • 1,385 posts
Posted 29 April 2022 - 08:38 AM
I think the fact that you should run relays is probably more the vital piece of information vs. the power of the bulbs. It was literally like night and day for me switching from crusty old loom wiring to a set of relayed thick gauge wires.
I'll second that. The difference with simply uprating the wiring on my '72 with it's original loom was quite dramatic.
#25 Nial
Nial
  • 75 posts
Posted 10 May 2022 - 09:03 AM
Sorry for the late reply, thanks for all the suggestions, even those no longer available O_O
I'm an electronic engineer so understand the need for relays/ thicker wire, but I was hoping to keep things looking as original as possible so will have a think.
Those Dapper lights look interesting!
Thanks again,
Nial
#26 sonscar
sonscar
  • 2,995 posts
Posted 10 May 2022 - 02:41 PM
You can use the existing wires to switch the relays,live is at the starter right at the front.Four miniature relays mounted behind the grille hardly seen,all removable when/ if a new buyer objects.All less obvious than sparkly new lenses.
I may be a Luddite but why not drive more slowly and or more carefully.Steady elderly driver talking.Steve..
#27 Chapperscfc84
Chapperscfc84
    Just On Tickover
  • 9 posts
Posted 11 June 2022 - 09:26 AM
They look the business but I’m yet to take them out at night!!!! Very very easy to fit. I’m struggling to post pics up here
#28 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 11 June 2022 - 10:33 AM
Use an image hosting site and post the IMG code into your post, this will put the pictures straight into your post
Edited by cal844, 11 June 2022 - 10:33 AM.
