27H4353 Bolt-Caliper Halves-8.4'' Brakes Thread Size
brakes
2 replies to this topic
#1 hungdynasty
hungdynasty
  • 173 posts
Posted 29 March 2022 - 02:23 PM
Hi, just wonder if anyone know the thread size and length of this bolt
27h4353 BOLT-CALIPER HALVES-8.4'' BRAKES
Thanks a lot!
Edited by hungdynasty, 29 March 2022 - 02:23 PM.
#2 richmondclassicsnorthwales
  • 942 posts
Posted 29 March 2022 - 05:18 PM
Pretty sure they are 7/16 thread x 20 TPI x 1.4 "
The machine bolts (BMC Part # 27H 4353) that are used to assemble the halves of the brake calipers are special 'Torque-To-Yield' bolts, and as such the factory always recommended that they should not be reused.
These machine bolts are torqued to a specific value, and then turned an additional number of degrees. How many more degrees is dependent upon the recommendation of the manufacturer
They have a shouldered head and shank, 7/16"-20 UNF x 1.4", and are marked on the head with three hash marks at 120 degree intervals, and the letter 'S' refers to the tensile strength of the machine bolt (50-55 Tons per square inch)
#3 hungdynasty
hungdynasty
  • 173 posts
Posted 29 March 2022 - 06:17 PM
Thank you very much!
Also tagged with one or more of these keywords: brakes
