Mini Van Battery Securing
14 replies to this topic
#1 Steve66
Steve66
  • 67 posts
Posted 28 March 2022 - 05:52 PM
Hi all,
can anyone please share a photo of exactly where and how the battery is fixed in a Mini Van
sorry if this has been covered but I can’t find any information
I am especially interested in any brackets that are used as I am currently restoring a Van
Steve
#2 MiniMadRacer
MiniMadRacer
  • 884 posts
Posted 28 March 2022 - 05:56 PM
If its the same as a Mini pickup, I can get pics tomorrow for you.. mine is one of the last though,  a 1981 998, not sure if "fixings" changed over the years
#3 Alex_B
Alex_B
  • 4,573 posts
Posted 28 March 2022 - 06:24 PM
Following this one, just got myself a van which is currently stripped and I am assuming the battery sits under the load bed on the drivers side but would be good to see how it should mount. Was also curious as to what the little triangular bracket that sits under the passenger seat.
#4 MiniMadRacer
MiniMadRacer
  • 884 posts
Posted 28 March 2022 - 06:36 PM
Yes my battery sits under the floor behind the drivers seat, the spare wheel sits under the floor behind the passenger seat (RHD UK Car). I think the triangular bracket is to hold the spare wheel down...also my battery sits in a tray, I might even have a spare one lying around... if I can ever find it..so its insulated from the floor... but .. mine is a pickup not a van
#5 Alex_B
Alex_B
  • 4,573 posts
Posted 28 March 2022 - 07:28 PM
That makes a whole lot of sense!
#6 Steve66
Steve66
  • 67 posts
Posted 29 March 2022 - 07:29 AM
Mine has a bracket welded under the load bed but I have asked the question because every other van I have seen doesn’t have this bracket and I am wondering if it has been fitted by a previous owner?. The floor behind this bracket is totally rotten and very awkward to change unless you are using a rotisserie.
Edited by Steve66, 29 March 2022 - 07:32 AM.
#7 KTS
KTS
  • 2,411 posts
Posted 29 March 2022 - 08:42 AM
the battery would be clamped against the upright in the picture using a battery bar (link below), and a pair of long battery bolts hooked through the holes in the lower horizontal panel
https://www.minispar...px|Back to shop
as mentioned above, plastic battery trays were also used to provide some protection from acid spills.
Edited by KTS, 29 March 2022 - 08:42 AM.
#8 Steve66
Steve66
  • 67 posts
Posted 29 March 2022 - 09:41 AM
Is this original though is my question as most I have seen are like the below without the welded bracket. Has mine just been added later someone.  As it is a restoration I am hoping to go for originality. Thanks
#9 KTS
KTS
  • 2,411 posts
Posted 29 March 2022 - 10:09 AM
both pickups i've owned ( a '78 and an '81) have had the bracing between the load bed and floor behind the drivers seat.
as above, it's quite possible that this bracing was not present on earlier models
#10 Steve66
Steve66
  • 67 posts
Posted 29 March 2022 - 10:35 AM
Ok thanks.  Bracket is staying then
#11 Vanman20
Vanman20
  • 274 posts
Posted 29 March 2022 - 02:09 PM
Mine is like Steve's.
I bought a battery that would slide under so I could adjust the seat back as far as possible
https://i.ibb.co/SwH...0329-150152.jpg
#12 nev100
nev100
  • Just Joined
  • 143 posts
Posted 29 March 2022 - 08:36 PM
Hi Steve66.
I've got a 1976 Van and it has the upright panel like yours between floor and load bed.
I've nearly completed a full nut and bolt restoration and it was definitely in there beforehand
#13 bpirie1000
bpirie1000
  • Area Managers
  • 2,316 posts
  • Local Club: Amoc
Posted 30 March 2022 - 02:23 PM
My 1961 van has the bracket..
#14 Steve66
Steve66
  • 67 posts
Posted 31 March 2022 - 07:54 AM
Thanks everyone, bracket is staying.
Have to say this is a great forum
#15 IronmanG
IronmanG
  • 1,223 posts
  • Local Club: Box hill. Lsmoc member
Posted 31 March 2022 - 11:20 AM
Mine has the bracket. I am using a rachet strap temporarily
