Had a strange one today. A friend has a 1275 metro engined mini which broke down. Long story but discovered today that the ignition had retarded itself about 10-15 degrees so that the engine would not start. Swapped complete ignition system to a spare I have and the same. Advanced as far as it would go until the distributor fouled the oil pipe and it runs. Changed back to original system and it runs at this new setting.
The timing chain is rattling its brains out and I was wondering if the chain has jumped a tooth and put the valve timing out. I did notice that about half of the rockers were way too tight. Going to set to tdc (7 & 8 rocking) in a couple of days and see if the pistons are actually at tdc.
A compression test showed between 65 and 70psi across all cylinders.
Rotor arm not 'wandering' on drive spigot.
Anyone come across this in a Mini engine.
A+ MG Metro engine with 65DM4 distributor.
The distributor had not moved from its previous set position when the breakdown occurred.
Edited by whistler, 28 March 2022 - 09:02 AM.
