Whats The Best Engine Oil To Use For My 1380Cc Classic Mini
15 replies to this topic
#1 Marc13
Marc13
  • 216 posts
Posted 06 March 2022 - 12:11 PM
Hi,
its time for me to do the 1st oil change since I've owend the Mini - qhats the best engine oil to use - its a 1380cc?
Marc
#2 nicklouse
  • 18,574 posts
Posted 06 March 2022 - 01:15 PM
The engine size has little to do with what oil to use.
what gear box has greater impact. If an Auto you should use a totally different oil to a manual but I don’t think this will be an auto?
the there is what you use it for. Standard road use the same as forma standard car. Competition use you might want to use something else.  But with any Mini regular oil changes are a must.
#3 Cooperman
  • 23,276 posts
Posted 06 March 2022 - 01:23 PM
The VERY best oil for the classic Mini is, IMHO, Kendall 20w50. This is expensive and can be hard to find in th UK.
Valvoline VR-1 is the oil of choice for many of us. It has a good ZDDP level (zinc addditive) which the gearbox needs and holds its viscosity well even when used in competition. It is easily available as well.
#4 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 06 March 2022 - 01:53 PM
Amazon sell Kendall 20W50.. of course they do ...
https://www.amazon.c...n/dp/B00NORLQI6
#5 MiniCarJack
MiniCarJack
    Formally known as W1NG3D
  • Just Joined
  • 486 posts
  • Local Club: Midweek Minis
Posted 06 March 2022 - 02:08 PM
I've used Valvoline VR1 previously and liked it, but have also had similarly good results from Millers' 20w50 Classic Mini Oil. Both are readily available and would be a good choice for a road-going mini with a manual gearbox.
#6 JXC Mini GT
JXC Mini GT
  • 842 posts
Posted 06 March 2022 - 02:39 PM
What is the general view on Minispares 20 / 50 oil, with a Zinc/ZDDP (1300ppm)?
#7 whistler
whistler
  • 1,791 posts
Posted 06 March 2022 - 04:04 PM
I use it on 3 engines. Alternatively I use Halfords Classic 20w50 for road use.
#8 Miki Leyland
Miki Leyland
  • 123 posts
Posted 06 March 2022 - 11:31 PM
I have always used Millers Classic Mini and last year changed to Valvoline Vr1 20W50 due to lack of availability here after the Brexit. A bit of dissapointment to me as does not seem to hold the pressure as well as the Millers did on the hot Iberic days. Works fine to me under 15ÂșC.
#9 Marc13
Marc13
  • 216 posts
Posted 15 July 2022 - 03:48 PM
Just picking up on this - got delayed a little!
Oil ordered.
Are there any recommendations for the oil filter?
#10 PoolGuy
PoolGuy
  • 848 posts
Posted 15 July 2022 - 06:06 PM
The fact that it's sold in 3.75litre containers is enough to put me off buying it and stick to the sensibly packaged VR1.
#11 stuart bowes
stuart bowes
  • 2,100 posts
Posted 15 July 2022 - 07:51 PM
How much does a mini take by the way just curious for future ref. I suppose I would have just looked it up but seeing as this is a post on topic
#12 imack
imack
  • 2,103 posts
Posted 15 July 2022 - 08:10 PM
About 8 1/2 pints for a manual including filter. Plus another pint or so if you have an oil cooler
#13 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 15 July 2022 - 09:15 PM
Oil ordered.
Mahle OC21
Edited by cal844, 15 July 2022 - 09:15 PM.
#14 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 15 July 2022 - 09:16 PM
An A or A+ manual engine is 4.8 litres including filter
#15 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 16 July 2022 - 12:38 AM
Unless you're in a hot climate (England?) or have a worn engine unable to hold pressure, I'd recommend 10W40. It flows a lot better especially in a cold start up. Any of the above brands are fine.....
