Is It Possible To Reuse The Windscreen Rubber Seal?
9 replies to this topic
#1 hungdynasty
hungdynasty
  • 173 posts
Posted 25 February 2022 - 10:49 AM
Need advice. Replaced new windscreen and new seal a few months ago and windscreen crack again, is it possible to remove the cracked windscreen without damaging the rubber seal and reuse it? Thanks a lot.
#2 Ethel
  • 25,941 posts
Posted 25 February 2022 - 10:53 AM
Yes
#3 nicklouse
  • 18,593 posts
Posted 25 February 2022 - 11:52 AM
You can reuse them as much as you can.
#4 hungdynasty
hungdynasty
  • 173 posts
Posted 25 February 2022 - 12:25 PM
Thank you !
#5 goudoogje
goudoogje
  • 94 posts
Posted 25 February 2022 - 03:02 PM
my experience is that it will leak when replacing a screen and reuse the rubber seal.
#6 stuart bowes
stuart bowes
  • 2,118 posts
Posted 25 February 2022 - 03:18 PM
how much is a new one, £10?  might as well just replace it surely
Edited by stuart bowes, 25 February 2022 - 03:18 PM.
#7 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 25 February 2022 - 03:58 PM
You can reuse them, my suggestion from experience is to use a new seal and use screen sealant from a window fitters....
#8 mab01uk
mab01uk
  • 12,421 posts
Posted 25 February 2022 - 04:20 PM
A lot depends on the age of the seal and how hard or cracked/perished the rubber has become over time. If in doubt replace but also beware that many new rubber parts for Minis don't seem to last as long as the original items did so look for quality from a specialist like Minispares rather than a low price from an unknown supplier of cheap copies which crack and shrink over time on ebay....
Edited by mab01uk, 25 February 2022 - 04:24 PM.
#9 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 February 2022 - 05:07 PM
I've never needed to use any sealant and would hesitate to recommend it.
I would say the main cause for a leaking screen is likely to be incorrectly fitted fillet strip.
Ben
#10 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 25 February 2022 - 06:31 PM
I now always get my windscreens sealed in, purely to prevent corrosion and water leaks
