Coolant
8 replies to this topic
#1 Gcal
Gcal
  • 128 posts
Posted 15 February 2022 - 08:26 PM
I'm changing the coolant in my mini 35 and wondered if any one has used the Halfords OAT Ready Mixed Antifreeze in their cars or what's a better alternative
#2 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 15 February 2022 - 09:31 PM
I believe the stuff you mention is made by Comma. However I'd just go to my local garage or motor factors, it usually works out cheaper long term including the fuel to go there and home.
For what it's worth it actually depends what material your radiator is made from as the wrong antifreeze will soften or corrode the solder in the radiatior I believe.
What I usually do is buy 5 litres of concentrated antifreeze and dilute myself 50/50 with water
Just my thoughts
Edited by cal844, 15 February 2022 - 09:35 PM.
#3 Gcal
Gcal
  • 128 posts
Posted 15 February 2022 - 09:35 PM
Just running a standard radiator,just wasn't sure what coolant to use
#4 MatthewsDad
MatthewsDad
  • 814 posts
Posted 15 February 2022 - 09:57 PM
Just the standard blue ethylene glycol is fine with a standard rad. Cheap from discount stores, or with euro car parts discount etc.
#5 Gcal
Gcal
  • 128 posts
Posted 15 February 2022 - 10:12 PM
I have used the blue star ready mixed antifreeze made by car plan before just want to make sure I get a suitable antifreeze
#6 MikeRotherham
MikeRotherham
  • 976 posts
Posted 16 February 2022 - 12:21 PM
I use Bluecol diluted 50/50.
It's the one that needs changing every two years.
This is the blue version and not their clear Universal version
https://www.amazon.c...l,aps,98&sr=8-6
Car Plan Blue Star is also made by Tetrosyl who make Bluecol. I wouldn't be surprised if it's the same stuff.
Edited by MikeRotherham, 16 February 2022 - 12:32 PM.
#7 slidehammer
slidehammer
  • 1,196 posts
  • Local Club: LSMOC
Posted 16 February 2022 - 01:33 PM
I am pretty sure the OAT anti freeze isn't compatible with the existing anti freeze and the cooling systems seals and can cause leaks. Stick with blue Glycol based antifreeze and change it every 2 or so years
#8 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 16 February 2022 - 02:02 PM
Seals will be fine, it's the radiator and heater matrix that causes issues
#9 Gcal
Gcal
  • 128 posts
Posted 16 February 2022 - 06:41 PM
Thank you for all your replies I shall get some of the bluecol stuff it seems like a better option
