Did you find the answer in the end?
Oil Pump Priming - Gasket Sealing
mad4classics
, Feb 15 2022 11:02 AM
16 replies to this topic
#16
Posted 28 September 2023 - 12:25 PM
#17
Posted 28 September 2023 - 04:06 PM
Not totaly. I spent ages faffing with bolt lengths and went through a few gaskets; the rear bearing is just fed with unfiltered oil direct from the pump and does come out the internal side and run down to appear in that hole. If I hadn't been priming the pump without the transfer case on I would never have know.Did you find the answer in the end?
Just wanted it to be right having optimised the pump as per the article by AC Dodd in Nov 14 Mini World mag.
